I Can Only Imagine (US Retail)
Cornstick
Post by Cornstick » Thu May 31, 2018 12:11 am
This is what I got but I'm not at all sure it's correct.
Title information
Name: I Can Only Imagine (English)
Source file name: 00856.mpls
Duration: 1:50:20
Chapters count: 16
Segment count: 11
Segment map: 508,510,509,506,503,501,504,502,505,507,500
File name: I_Can_Only_Imagine_t328.mkv
UsedKondomXL
Re: I Can Only Imagine (US Retail)
Post by UsedKondomXL » Sat Jun 09, 2018 6:13 am
Has anyone been able to confirm this ?
hvnphoto
Post by hvnphoto » Sun Jun 10, 2018 8:40 pm
00856.MPLS is correct.
bill2468
Post by bill2468 » Tue Jun 12, 2018 1:50 pm
What about the Rebox version? 856 doesn't exist.
mgdrummond1
Post by mgdrummond1 » Tue Jun 12, 2018 7:00 pm
It's .mpls 993
bill2468
Post by bill2468 » Tue Jun 12, 2018 7:16 pm
MiraSun
Post by MiraSun » Sat Jun 16, 2018 3:28 pm
mgdrummond1 wrote:It's .mpls 993
Is there some method to figuring this out?
KENSAI
Post by KENSAI » Wed Jun 20, 2018 2:15 am
Thanks so much! I really appreciate the fact that I can always come here and find the answer I need. Y'all rock! :mrgreen:
iamgroot
Post by iamgroot » Thu Jun 21, 2018 2:29 am
Is this a title that MakeMKV is not able to determine the FPL?
I did just update to 1.12.2 WIN64 version and the custom java location was removed.
Updated Java to Version 8 Update 171
Post by Woodstock » Thu Jun 21, 2018 1:38 pm
In the log, does MakeMKV mention that it found Java? In the portion visible in your screen shot, it would appear it did not.
What happens if you REMOVE the "custom location" information, and let MakeMKV look for Java instead? A proper Java installation should have set variables in the operating system to point to the executable...
mike-da-ripper
Post by mike-da-ripper » Thu Jun 21, 2018 2:31 pm
Woodstock wrote:In the log, does MakeMKV mention that it found Java? In the portion visible in your screen shot, it would appear it did not.
I've tried allowing MakeMKV to find Java and pointing it out directly and Make doesn't use Java for this movie either way. I know it is working because it does use Java for Pacific Rim Uprising. For whatever reason this movie and Make 1.12.2 don't seem to get along.
kevinbagnaschi
Post by kevinbagnaschi » Fri Jun 22, 2018 1:08 pm
I'm guessing the Netflix version follows suit with Redbox? 856 is not available on this version either.
Thanks,
Kevin
Djimusic
Post by Djimusic » Wed Jun 27, 2018 2:24 am
For the Netflix version, I am showing the following Segment map information for 993:
Title information
Source file name: 00993.mpls
Duration: 1:50:20
Chapters count: 16
Segment count: 11
Segment map: 505,501,502,510,506,508,504,503,500,507,509
File name: I_Can_Only_Imagine_t409.mkv
jhughy2010
Post by jhughy2010 » Thu Aug 30, 2018 3:53 pm
The Netflix version I just received doesn't have 993.mpls, however it does have 856.mpls so maybe I'll try it. I also noticed java wasn't used.
EmKayVe
Post by EmKayVe » Fri Aug 31, 2018 12:42 am
The 993.mpls seems correct, although I haven't watched it in its entirety.
