This is what I got but I'm not at all sure it's correct.
Title information
Name: I Can Only Imagine (English)
Source file name: 00856.mpls
Duration: 1:50:20
Chapters count: 16
Segment count: 11
Segment map: 508,510,509,506,503,501,504,502,505,507,500
File name: I_Can_Only_Imagine_t328.mkv
I Can Only Imagine (US Retail)
UsedKondomXL
Re: I Can Only Imagine (US Retail)
Has anyone been able to confirm this ?
hvnphoto
00856.MPLS is correct.
bill2468
What about the Rebox version? 856 doesn't exist.
mgdrummond1
It's .mpls 993
MiraSun
Is there some method to figuring this out?mgdrummond1 wrote:It's .mpls 993
KENSAI
Thanks so much! I really appreciate the fact that I can always come here and find the answer I need. Y'all rock!mgdrummond1 wrote:It's .mpls 993
iamgroot
Is this a title that MakeMKV is not able to determine the FPL?
I did just update to 1.12.2 WIN64 version and the custom java location was removed.
Updated Java to Version 8 Update 171
In the log, does MakeMKV mention that it found Java? In the portion visible in your screen shot, it would appear it did not.
What happens if you REMOVE the "custom location" information, and let MakeMKV look for Java instead? A proper Java installation should have set variables in the operating system to point to the executable...
mike-da-ripper
Woodstock wrote:In the log, does MakeMKV mention that it found Java? In the portion visible in your screen shot, it would appear it did not.
I've tried allowing MakeMKV to find Java and pointing it out directly and Make doesn't use Java for this movie either way. I know it is working because it does use Java for Pacific Rim Uprising. For whatever reason this movie and Make 1.12.2 don't seem to get along.
kevinbagnaschi
I'm guessing the Netflix version follows suit with Redbox? 856 is not available on this version either.
Thanks,
Kevin
Kevin
Djimusic
For the Netflix version, I am showing the following Segment map information for 993:
Title information
Source file name: 00993.mpls
Duration: 1:50:20
Chapters count: 16
Segment count: 11
Segment map: 505,501,502,510,506,508,504,503,500,507,509
File name: I_Can_Only_Imagine_t409.mkv-
jhughy2010
The Netflix version I just received doesn't have 993.mpls, however it does have 856.mpls so maybe I'll try it. I also noticed java wasn't used.
EmKayVe
The 993.mpls seems correct, although I haven't watched it in its entirety.
