2D Version is OK.
3D Version starts to load and even shows the titles in the background as the app crashes. Debug log attached; can anyone help?
Justice League 3D - Crashes MakeMKV
Krobar
Re: Justice League 3D - Crashes MakeMKV
Are there any Windows events associated with the crash?
This is likely something that will have to be sent directly to Mike via email, support@makemkv.com . Send the items listed in the FAQ link in my signature, along with any Windows events associated with it.
Krobar
Nothing in the Windows App or System logs. Makemkv is crashing for all disks now; finishes the disc status bar and then crashes as the title checkboxes should appear (As you click to close the program it gives a glimpse of the titles). If anyone could help I would appreciate it.Woodstock wrote:Are there any Windows events associated with the crash?
Krobar
Eventually found a solution to this. You need to install an older version of Makemkv and then reinstall the current version. Just reinstalling the current version did not help.
