Adventure Time Season 7 Blu-Ray (AU Version)
lobochrome
Post by lobochrome »
Hi Guys,
since it is incredibly hard to get a decent quality version of AT I ordered the OZ Blu-Ray of Season 7.
When I import the disc though, MakeMKV only recognises 2min snippets of each episode.
Anybody have any hints at how I can get this to work?
Thank You
lobochrome
Re: Adventure Time Season 7 Blu-Ray (AU Version)
what does the INFO window show when you highlight the title ABOVE the one you expanded? At 17.6GB, that's about 90 minutes in length.
lobochrome
Usually there is one track containing all episodes in a row.
However the segment map is not a lot of help trying to piece stuff together manually I think.
This Season should contain 43 Episodes of about 11min in length - so even this long track seems to be short of segments.
I've really never seen anything like it in MakeMKV. Is it because the disc is Australian?
According to https://en.wikipedia.org/wiki/Adventure_Time , season 7 is 25 episodes long, with the last one being 2 of the original aired 26.
That means that first track is the whole season in one file, with 3 chapters per episode.
Rip that one, and look at one of the tools out there to split it into separate episodes, like mkvtoolnix or handbrake. I've got a similar issue where where 26 episodes are stuffed into one file, and I have to make sure the "5 chapters per episode" is correct before I turn handbrake loose on it.
