Asus BC-12D2HT
xmenw
Re: Asus BC-12D2HT
Post by xmenw » Wed Jun 06, 2018 11:07 pm
mrtibbs wrote:Yes I'm also looking for a clean 300 firmware to flash with. I'll host it if need be with my dropbox account for others
I couldn't find one but I read it is safe to flash with the Asus BW-16d1HT. Its in the clean files zip linked to op. I did use that firmware and was able to read UHD discs.
https://forum.redfox.bz/threads/dumping ... ost-482704
mrtibbs
Re: Asus BC-12D2HT
Post by mrtibbs » Fri Jun 08, 2018 10:05 am
I've done this method ...just was curious if I could get my hands on a clean 300
xmenw
Re: Asus BC-12D2HT
Post by xmenw » Tue Jun 12, 2018 4:37 am
mrtibbs wrote:I've done this method ...just was curious if I could get my hands on a clean 300
Yep, I gave up, but if you do find the vanilla 300, please do post here, I'll use it to get my drive to that firmware too. I'll do the same if I come across the firmware.
flynn
Re: Asus BC-12D2HT
Post by flynn » Wed Jun 13, 2018 1:03 pm
What do you mean with clean/vanilla firmware? Would a dump from a drive which came with the 3.0.0 be enough?
bill2226
Re: Asus BC-12D2HT
Post by bill2226 » Sun Jun 17, 2018 3:17 am
GoofeyGuy wrote:
TeddyRaspin wrote:@GoofeyGuy
Hi mate, if you (or your friend) need, I've the 3.00 firmware and I can create a working one for your friend. :wink:
Would be great, just tried myself with the 3.0.0 from myce, ended up killing the drive, but always a good thing dosflash could wake it to life again
I have 3 of the ASUS BC-12D2HT drives which i just received from Amazon. All of these drives have version 3.01 firmware and i would like to fix them to work with UHD disks. I am not super technical but i can flash the drives if someone can be so kind and post the corrected firmware to make them work or email it to me...
Thanks again great people !! Email: billinabnett@gmail.com
Bill
xmenw
Re: Asus BC-12D2HT
Post by xmenw » Mon Jun 18, 2018 1:44 pm
flynn wrote:What do you mean with clean/vanilla firmware? Would a dump from a drive which came with the 3.0.0 be enough?
Yep that would be it, please upload if you can.
flynn
Re: Asus BC-12D2HT
Post by flynn » Mon Jun 25, 2018 9:21 pm
Sorry for the delay... here you go.
dump_ASUS_BC-12D2HT_3.00.zip
(1.11 MiB) Downloaded 3157 times
xmenw
Re: Asus BC-12D2HT
Post by xmenw » Mon Jul 02, 2018 1:55 pm
flynn wrote:Sorry for the delay... here you go.
Thank you Sir!
devonuto
Re: Asus BC-12D2HT
Post by devonuto » Sun Jul 29, 2018 12:32 am
I have a BC-12D2HT that came loaded with 3.01, running this with Admin privs.
What am I doing wrong?
PS D:\flasher_Win64_10252010_1137PM> .\flasher.exe -d 2 -m main_firmware.bin
Devilsclaw's LG Renesas Drive Utility
cmd_drive: Opening Drive: 2.
drive_open: Cannot open device c.
drive_open: Cannot open device d.
cmd_dumpmain: Starting dumping process
get_firminfo_drive: failed to find pattern
cmd_dumpmain: failed to get firmware info
PS D:\flasher_Win64_10252010_1137PM> .\flasher.exe -d 2 -c core_firmware.bin
cmd_dumpcore: Starting dumping process
cmd_dumpcore: failed to get firmware info
PS D:\flasher_Win64_10252010_1137PM> .\flasher.exe -d 2 -f "D:\dump_ASUS_BC-12D2HT_3.00\dump_ASUS_BC-12D2HT_3.00.bin"
cmd_flashfirm: Flashing process started
firm_flasher: Drive should be flashing its light.
firm_flasher: This indicates its flashing its self.
firm_flasher: This can take a while, Please be patiant.
firm_flasher: Failed to write at 0x00000000
firm_flasher: your drive should still be fine.
cmd_flashfirm: Flashing process failed
Zealous
Re: Asus BC-12D2HT
Post by Zealous » Wed Oct 10, 2018 11:45 am
I got the same problem
jonghotti
Re: Asus BC-12D2HT
Post by jonghotti » Thu Oct 11, 2018 7:17 am
Just wait til <doozah> shows up he'll get it rockin'.
Here's the contents of the usb stick I use: https://drive.google.com/open?id=1393Iu ... jCb1TbarW4
Nothing specifically says 12 in it's title though.
Re: Asus BC-12D2HT
Post by d00zah » Thu Oct 11, 2018 7:55 am
Haven't seen a clean Asus BC-12D2HT FW. Someone (above) reports success with a crossflash.
Terramex
Re: Asus BC-12D2HT
Post by Terramex » Sat Oct 13, 2018 11:18 am
Even though a dump has already been attached here's also a clean 3.00 firmware.
But as it's "slow" as most LG drives i'd recommend to use the BW-16D1HT firmware on that combo drive.
flash_ASUS_BC-12D2HT_3.00.zip
(1.11 MiB) Downloaded 2505 times
jonghotti
Re: Asus BC-12D2HT
Post by jonghotti » Wed Oct 17, 2018 1:08 am
Terramex wrote: Sat Oct 13, 2018 11:18 am Even though a dump has already been attached here's also a clean 3.00 firmware.
God bless the unlocked flasher!!!
jonghotti
Re: Asus BC-12D2HT
Post by jonghotti » Thu Oct 18, 2018 4:26 pm
There seems to be very little this cross flasher cannot do. I've got six different drive models, all ASUS and LG of course, all reporting in as BW-16D1HTs and the read speed is solid. I'm watching a BC-12D2HT and an WH14NS40 both read at 7.7X sustained when it hits the main m2ts file and really gets to open up. This is great.
