Ripping Dolby Atmos into MKV
Zaphod
#1 Post by Zaphod » Sat Jun 16, 2018 4:40 pm
Does Make MKV pull across the Dolby Atmos soundtrack when a UHD disk is ripped.
If so how would you recognise the Dolby atmosphere track in Handbrake for pulling into a MP4 file ?
buffalo master
Re: Ripping Dolby Atmos into MKV
#2 Post by buffalo master » Sat Jun 16, 2018 5:45 pm
Zaphod wrote:Does Make MKV pull across the Dolby Atmos soundtrack when a UHD disk is ripped.
No.
There's a big thread talking about it right below yours. The short version is Atmos is closed source and nobody knows how to reverse engineer it for ripping.
st4evr
#3 Post by st4evr » Sat Jun 16, 2018 7:22 pm
No.
To clear things up. The OP is referring to the Dolby "Atmos" track which is the audio track. Not Dolby "Vision" which is the HDR layer (video related), and which is what the MKV community has yet to resolve.
st4evr
#4 Post by st4evr » Sat Jun 16, 2018 7:25 pm
Yes, you should be able to pack the Atmos track into the MKV container. I have done it and so have other people.
However, I do NOT use Handbreak. Best way to know for sure? Try it and test it. It will not explode if you try and fail I promise.
buffalo master
#5 Post by buffalo master » Sat Jun 16, 2018 11:37 pm
No.
Ah, got mixed up.
Yeah, Atmos rips fine. It'll even say Atmos in the right box of the correct track. "TrueHD Atmos"
ibluetooth
#6 Post by ibluetooth » Tue Mar 12, 2019 10:57 pm
Hi there,
Apologies for the NEWB question - I'm wondering how I would select the Atmos Track to rip from a UHD BluRay?
I don't see anything listed as Atmos - most I see is True HD 7.1 and DD Plus Surround 7.1
Am I missing something?
bmillham
#7 Post by bmillham » Wed Mar 13, 2019 4:40 am
Select the 7.1 track and look at the right window. In the Info section you will see the codec which probably will be Atmos.
Metallikahn
#8 Post by Metallikahn » Wed Mar 13, 2019 6:45 pm
Yep, what bmillham said. Dolby Atmos is just metadata tacked on to a True HD track. I've got over a 100 UHD's with Atmos tracks that play and decode fine on my receiver (atmos flag lights up and sound comes out of the height speakers.) DTS-X also works perfectly.
The only issue I have with atmos is on a few Disney releases and 1 or 2 Lionsgate films that will have audio dropouts when playing the atmos track. The core audio works fine, but you lose the height speakers and lossless audio. These movies have no issue when actually playing the physical disc... just the MKV. The Incredibles 2 and Leon the Professional are the worst two I've come across. No idea how to fix this yet. I might try folder rips on them and then different extraction remuxing if those work fine.
#9 Post by SamuriHL » Wed Mar 13, 2019 6:52 pm
I've got an open issue with another ripping solution for that issue. Specifically on Incredibles 2 which is by far the worst one I've seen. LAV Filters were updated to handle it better. With MakeMKV it has audio drops and sometimes the audio recovers and sometimes it doesn't. With the other ripping solution I use, the audio doesn't drop but it slowly gets out of sync. These Disney animated ones are horrible like that. However, on that other product's forum, someone posted an interesting idea that they say works to fix this issue. Basically create your MKV with just video. Then extract the audio with eac3to (or one of the many GUI's available to automate it). Then use mkvtoolnix to combine the extracted audio with the MKV containing the video. They say that then works fine. Good luck if you try it!
Metallikahn
#10 Post by Metallikahn » Wed Mar 13, 2019 7:03 pm
I was wondering if something like that might works as well. Just to be clear, in order to do this, I would have to do a folder rip/backup of the disc as well in order to get the atmos track extracted before remuxing in mkvtoolnix, correct?
#11 Post by SamuriHL » Wed Mar 13, 2019 7:06 pm
Ah, yea, that's a very good point. Yes, you would indeed have to do a folder rip to make that work. I'd probably just do the folder rip first and rip everything from that to save some wear and tear on the drive.
TheShoe
#12 Post by TheShoe » Wed Mar 13, 2019 10:23 pm
the latest lav update fixed all audio drop outs for me and others for atmos tracks.
give it a try.
Metallikahn
#13 Post by Metallikahn » Wed Mar 13, 2019 10:40 pm
give it a try.
Would, but I'm streaming to an Oppo 203 (so disappointed Oppo stopped making players and stopped updating the firmware on this... best player of any kind I've ever had!) , which has nothing to do with lav. Oh well... I've got Incredibles 2 multiplexing right now with the newly extracted atmos track. I'll give it a try later tonight when it's finished and see whats up.
#14 Post by SamuriHL » Wed Mar 13, 2019 10:49 pm
give it a try.
I have, believe me. I was testing it on the JRiver forum when Nev was fixing it. It does not fix ALL the audio dropouts. It vastly improved the situation, but, with a MakeMKV rip of Incredibles 2 I still get audio drops periodically.
ibluetooth
#15 Post by ibluetooth » Thu Mar 14, 2019 2:47 am
Thanks! I see it now - and the my receiver does recognize Atmos when playing back the movie. Awesome.
Thanks again.
