[SOLVED] Optical disk drive unrecognized
pmatos
Post by pmatos » Mon Jun 11, 2018 1:23 pm
I have a bluray drive on a recent arch installation that's not detected even though I am a member of the optical group. Even running under sudo does not help.
It just says
the program cannot find any usable optical drives.
Is there a verbose flag or something so I can understand what's actually going on? I can mount (/dev/sr0) and watch dvds using it in mplayer.
pmatos
Re: Optical disk drive unrecognized
Post by pmatos » Mon Jun 11, 2018 1:31 pm
pmatos wrote:I have a bluray drive on a recent arch installation that's not detected even though I am a member of the optical group. Even running under sudo does not help.
It just says
With debug I get this in the debug file:
Debug log started at Mon Jun 11 13:30:17 2018 , written by MakeMKV v1.12.2 linux(x64-release)
001005:0000 MakeMKV v1.12.2 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/pmatos//MakeMKV_log.txt
001003:0020 DEBUG: Code 2 at O9F4i`a@>+vYs)L9K@~q/p,k:121261428
005042:0000 The program can't find any usable optical drives.
Post by Woodstock » Mon Jun 11, 2018 1:36 pm
Have you read through this topic yet? http://makemkv.com/forum2/viewtopic.php?f=3&t=16939
pmatos
Post by pmatos » Mon Jun 11, 2018 2:25 pm
Woodstock wrote:Have you read through this topic yet? http://makemkv.com/forum2/viewtopic.php?f=3&t=16939
Thanks for the reference.
alienbob64
Re: [SOLVED] Optical disk drive unrecognized
Post by alienbob64 » Thu Jun 14, 2018 11:24 pm
What I discovered when I had this issue was that the default Installation folder was "C:/Program Files (x86)" (32 bit install folder)
Looking at task manager I saw this process running;
MakeMKV application (32 bit)
Since I am running a Windows 10 64 bit, I changed the install folder to "C:/Program Files" (64 bit install folder) and that seems to have fixed the issue,
as long as you run as administrator.
Looking at task manager I now see these processes running;
MakeMKV console Application (Properties indicate this process is associated with makemkvcon64.exe)
pmatos
Post by pmatos » Fri Jun 15, 2018 12:48 pm
alienbob64 wrote:What I discovered when I had this issue was that the default Installation folder was "C:/Program Files (x86)" (32 bit install folder)
I am on Linux. My problem was I was missing the sg kernel module. A modprobe sg, sorted it out.
