First Try, Probably Wrong Drive
GrayPockets
#1 Post by GrayPockets » Sat Jun 09, 2018 10:20 pm
So in anticipation of the coming UHD revolution, I bought a Pioneer BDR-XD06J-UHD back in March.
Today I plugged it in, downloaded the keys_hashed.txt, and fired it up.
Sadface, it will not rip the Ultra HD of Thor Ragnarok. (It does appear to rip Blu-Ray just fine)
Am I missing anything, or do I need a new UHD drive?
Manufacturer: PIONEER
Product: BD-RW BDR-XD06U
Revision: 1.11
Serial number: ~_~
Highest AACS version: 61
Disc Information
Label: THOR_RAGNAROK
Timestamp: 2018-01-02 18:33:10
Data capacity: 61.46 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Log
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom1'
Saved AACS dump file as C:\Users\matthew.peronto/.MakeMKV/MKB20_v61_MARVEL'S_THOR_RAGNAROK_5155.tgz
Re: First Try, Probably Wrong Drive
#2 Post by Woodstock » Sat Jun 09, 2018 10:25 pm
"Cannot write to medium" usually means you're trying to output to a read-only disk. What did you put in for your output directory?
#3 Post by d00zah » Sat Jun 09, 2018 10:27 pm
'The volume key is unknown for this disc - video can't be decrypted'
Consult the list of 'UHD friendly' drives:
http://www.makemkv.com/forum2/viewtopic ... 16&t=16832
rivey
#4 Post by rivey » Sat Jun 09, 2018 11:24 pm
To be precise, what you bought is a official UHD drive. They currently can not be used to rip UHD discs. You need one of the UHD friendly drives that are referenced in d00zah's post above. At some point an official drive might be made to work but not at this time. There are some issues about the firmware on the friendly drives but that can be dealt with. You can go over that by doing a search for "friendly drives" on this board. Good Luck.
st4evr
#5 Post by st4evr » Sun Jun 10, 2018 2:32 am
To be clear. UHD BD decryption support for Pioneer drives (specially Pioneer official UHD drives) has been addressed by Mike (MakeMVK owner/developer) already on multiple occasions (as well as others outside of this forum). They will NEVER be supported.
Example:
http://www.makemkv.com/forum2/viewtopic ... ver#p60673
Details as to why? Google.
GrayPockets
#6 Post by GrayPockets » Sun Jun 10, 2018 11:57 am
Thanks all. I suspected that. :?
