Help finding correct file
gabesdaddee
Post by gabesdaddee »
I am trying to rip "The Exception" and there are 402 files to choose from. There are too many files for me to copy over at once and I am not sure that I have the patience in ripping this movie 402 times to find the correct file. I tried using javaportable.ini, but I received the following message:
MakeMKV v1.12.2 win(x64-release) started
Using Java runtime from E:/Java/JavaPortable.ini
Failed to execute external program 'java' from location 'E:/Java/JavaPortable.ini'
Can someone help me out with this?
Attached is the log file.
Thanks all.
Regards,
Gabesdaddee
Re: Help finding correct file
Post by d00zah »
I use a portable version of java & the path should point to 'java.exe' (i.e. '.../java/bin/java.exe').
You want the path to the executable file, not the initial settings (ini) file.
gabesdaddee
Thank you both. That was some kind of stupid on my part. I was multi tasking and getting an earful at the same time. I appreciate it. BTW, love how Java really makes it so much simpler.
