Help finding correct file
gabesdaddee
#1 Post by gabesdaddee » Fri Jun 08, 2018 11:00 pm
I am trying to rip "The Exception" and there are 402 files to choose from. There are too many files for me to copy over at once and I am not sure that I have the patience in ripping this movie 402 times to find the correct file. I tried using javaportable.ini, but I received the following message:
MakeMKV v1.12.2 win(x64-release) started
Using Java runtime from E:/Java/JavaPortable.ini
Failed to execute external program 'java' from location 'E:/Java/JavaPortable.ini'
Can someone help me out with this?
Attached is the log file.
Thanks all.
Regards,
Gabesdaddee
The Exception Log.txt
(19 KiB) Downloaded 534 times
Re: Help finding correct file
#2 Post by d00zah » Fri Jun 08, 2018 11:34 pm
I use a portable version of java & the path should point to 'java.exe' (i.e. '.../java/bin/java.exe').
#3 Post by Woodstock » Sat Jun 09, 2018 12:01 am
You want the path to the executable file, not the initial settings (ini) file.
gabesdaddee
#4 Post by gabesdaddee » Sat Jun 09, 2018 12:06 am
Thank you both. That was some kind of stupid on my part. I was multi tasking and getting an earful at the same time. I appreciate it. BTW, love how Java really makes it so much simpler.
