Hey this happened trying to copy wanted it has also occured on acouple of others that i dont remember the names
the disk is clean no fingerprints or smudges most others rip perfectly (great program thanks)
Error 'Scsi error - UNIT ATTENTION:POWER ON, RESET, OR BUS DEVICE RESET OCCURRED' occured while reading '/BDMV/STREAM/00009.m2ts' at offset '3947360256'
Failed to save titles error
- Contact:
Re: Failed to save titles error
bad usb cable
cant be its an internal drive
mega multi blue or something its an lg
- Contact:
Then check internal signal and power cables and/or upgrade driver firmware. The error clearly looks like a drive problem.
how do i test the signal ? it is the latest firmware
some it has no prblem with others have this problem
it jus freezes and the outputsize doesnt get any bigger untill iy gave that error message
@razldazl
It's obviously a hardware problem (inconsistent - weak or failing connection or drive) that has nothing to do with MakeMKV.
I'd suggest you perform a Googlesearch for: "Scsi error - UNIT ATTENTION:POWER ON, RESET, OR BUS DEVICE RESET OCCURRED"
Fyi this seems to be fixed now i updated my mother board bios and have not had this error in 4 rips now fingers crossed the problem is fixed
Congratulations ;>}
