I didn't have to rename it. It automatically created a .bin file. Did you have a different experience?xmenw wrote:Does anyone know for the Asus BC-12D2HT, which drives firmware can be cross-flashed to bring to read UHD dics, as mine is on 3.01 and not reading UHD dics.
Did you rename the file with the .bin extension? I missed that the first time.sirleepalot wrote:I have gone through the Windows method for generating a dump file for my Asus BW-16D1HT but when I open the eeprom data mover.exe and try to select the dump file I created with DosFlash, it says "Incorrect firmware file." I created another file with a different name just to double check with the same results. Any suggestions?
sirleepalot
Re: 100% Firmware Downgrade for ASUS BW-16D1HT and LG BH16NS
xmenw
I did, but I ended up using the clean firmware files in the end.sirleepalot wrote:I didn't have to rename it. It automatically created a .bin file. Did you have a different experience?xmenw wrote:Does anyone know for the Asus BC-12D2HT, which drives firmware can be cross-flashed to bring to read UHD dics, as mine is on 3.01 and not reading UHD dics.
sirleepalot
For clarification's sake, are you saying that you can skip creating the dump of the current firmware on the drive and just use the download link on the forum? Because I read that it is extremely risky to do that.xmenw wrote:
xmenw
Sorry no I didn't mean that. You have to download your rom first, and then the 2nd time you can use the clean firmware, it takes info from your rom, and puts it in the clean rom.sirleepalot wrote:For clarification's sake, are you saying that you can skip creating the dump of the current firmware on the drive and just use the download link on the forum? Because I read that it is extremely risky to do that.xmenw wrote:
sirleepalot
Okay, that's what I thought. I am trying to understand what I could have done wrong in creating the initial bin since the data mover will not accept it. If I can't figure this out, I am really hoping that foolproof method other members have mentioned drops soon.xmenw wrote:
mgibsoni
Is there a no other way to downgrade the firmware? I just bought the ASUS BW-16D1HT with the 3.02 Firmware. My motherboard doesn't support IDE. I'll double check again but I didn't see that option.
xmenw
I did it using an older laptop, in its bios it had a 'compatibility mode' for its sata hdd, which is IDE on sata. SInce you can boot with the Win 7 USB in op, I unplugged the HDD, and connected my disc drive using a sata extension cable available on amazon ~$5. Its not a simple way and you still need a not so new laptop, but thats one way to do it. I have done this with 2 drives using that old laptop.mgibsoni wrote:Is there a no other way to downgrade the firmware? I just bought the ASUS BW-16D1HT with the 3.02 Firmware. My motherboard doesn't support IDE. I'll double check again but I didn't see that option.
mgibsoni
thanks. I have an older PC in the basement, maybe I will try to piece it together enough to try this out.xmenw wrote:I did it using an older laptop, in its bios it had a 'compatibility mode' for its sata hdd, which is IDE on sata. SInce you can boot with the Win 7 USB in op, I unplugged the HDD, and connected my disc drive using a sata extension cable available on amazon ~$5. Its not a simple way and you still need a not so new laptop, but thats one way to do it. I have done this with 2 drives using that old laptop.mgibsoni wrote:Is there a no other way to downgrade the firmware? I just bought the ASUS BW-16D1HT with the 3.02 Firmware. My motherboard doesn't support IDE. I'll double check again but I didn't see that option.
TechMan21
If anyone is looking for LG WH16NS40 drives brand new with 2018 manufacture date downgrade from 1.03 to 1.02 or cross flashed to ASUS BW-16D1HT 3.01 as they say the read speed is faster, I have them for sale $85 including shipping. I can also do the ASUS BW-16D1HT drives as well but the LG's are more affordable with the same parts
TechMan21
Also If you have your own drive and need it downgraded, I can do it for $25
jonghotti
jonghotti
jonghotti
TechMan21
It's funny you say that because on my other post you tried to sell them yourself smh, Also if you read the forums those drives you speak of are hard to come by new without spending an arm and a leg on new, screw him I was just trying to help out the community for people who didn't have the equipment or time to do it themselves before they change the drive again, anyway I will tell you guys how to do it free on your on with the right motherboard and version of windows, very simple opposed to some of the instructions on here but don't get me wrong you guys instructions helped alot for me to find an easier way, will post soon
jonghotti
