Weird issue...
Just installed an internal blu-ray rom LG CH10LS20 into a USB enclosure...hooked it up to my laptop (Win XP)
I pop in a Blu-ray...disc gets read fine....I am able to rip with anydvd....as soon as i open Makemkv it says reading disc then hangs....eventually it stops then says no disc located in the drive....say i flip back to anydvd it now says the same thing as well....i have to power off the drive and power on to get anydvd to recognize the disc again which it does fine and will rip with success....the second i open makemkv everything goes haywire....
Any suggestions?
MakeMKV not reading disc
dovidio815
Re: MakeMKV not reading disc
Btw...functions properly if i insert a regular DVD into the newly installed drive
dovidio815
OWC enclosure is at fault....according to an earlier post in the forum....wow that's weird....vantec it is
