The Sorcerer's Apprentice
thedukeo8
#1 Post by thedukeo8 » Mon May 28, 2018 4:48 pm
Every time I try to backup my copy using version 1.12.2 it times out or fails. Is there some setting or something I need to enable? I haven't had this much trouble with any of my other discs.
Re: The Sorcerer's Apprentice
#2 Post by Woodstock » Mon May 28, 2018 8:21 pm
Sorcerer's Apprentice doesn't come up here as a "hard to rip" disk... are there any error messages that come up when you rip it?
thedukeo8
#3 Post by thedukeo8 » Tue May 29, 2018 12:04 am
MakeMKV simply seems to hang. I get the spinning circle that and a message that says the program has stopped responding. I hadn't seen that before.
#4 Post by Woodstock » Tue May 29, 2018 1:40 am
No output at all usually means it's hung up waiting for the operating system to respond to a query.
Are there any device errors logged by the operating system? How long do you "let it spin" before you force it to stop?
thedukeo8
#5 Post by thedukeo8 » Tue May 29, 2018 2:59 am
Good question, I typically notice it and let it go for about 20 min. I think I will give it a shot tomorrow and see if I can get more specific info to share.
thedukeo8
#6 Post by thedukeo8 » Tue May 29, 2018 2:42 pm
Tried again and the following happened:
any suggestions would be appreciated.
Sorc Apprent Error.PNG (117.68 KiB) Viewed 15994 times
rivey
#7 Post by rivey » Tue May 29, 2018 4:51 pm
Have you tried cleaning the disc first? Sometimes even a brand new disc out of the case can not be clean enough. I am now cleaning every new disc I get with disc cleaner and a microfiber cloth and have not had any failures. Just an idea.
thedukeo8
#8 Post by thedukeo8 » Tue May 29, 2018 6:06 pm
I did try cleaning, it, but I will try microfiber and not just my shirt. :wink:
rivey
#9 Post by rivey » Tue May 29, 2018 6:53 pm
thedukeo8 wrote:I did try cleaning, it, but I will try microfiber and not just my shirt. :wink:
Us a solution of 50/50 distilled water and rubbing alcohol along with a microfiber cloth.
I also use a microfiber cloth for cleaning my glasses and it works great.
