The Sorcerer's Apprentice
thedukeo8
Post by thedukeo8 »
Every time I try to backup my copy using version 1.12.2 it times out or fails. Is there some setting or something I need to enable? I haven't had this much trouble with any of my other discs.
Re: The Sorcerer's Apprentice
Sorcerer's Apprentice doesn't come up here as a "hard to rip" disk... are there any error messages that come up when you rip it?
thedukeo8
Post by thedukeo8 »
MakeMKV simply seems to hang. I get the spinning circle that and a message that says the program has stopped responding. I hadn't seen that before.
No output at all usually means it's hung up waiting for the operating system to respond to a query.
Are there any device errors logged by the operating system? How long do you "let it spin" before you force it to stop?
thedukeo8
Post by thedukeo8 »
Good question, I typically notice it and let it go for about 20 min. I think I will give it a shot tomorrow and see if I can get more specific info to share.
thedukeo8
Post by thedukeo8 »
Tried again and the following happened:
any suggestions would be appreciated.
Sorc Apprent Error.PNG (117.68 KiB) Viewed 15264 times
rivey
Post by rivey »
Have you tried cleaning the disc first? Sometimes even a brand new disc out of the case can not be clean enough. I am now cleaning every new disc I get with disc cleaner and a microfiber cloth and have not had any failures. Just an idea.
thedukeo8
Post by thedukeo8 »
I did try cleaning, it, but I will try microfiber and not just my shirt. :wink:
rivey
Post by rivey »
thedukeo8 wrote:I did try cleaning, it, but I will try microfiber and not just my shirt. :wink:
Us a solution of 50/50 distilled water and rubbing alcohol along with a microfiber cloth.
I also use a microfiber cloth for cleaning my glasses and it works great.
