Blurays Having 5 Episodes As One File
BagofSchmidt
#1 Post by BagofSchmidt » Fri May 25, 2018 6:26 am
So I have multiple Shonen Jump Blurays where they put most of the episodes on a disc into one 2 hour long file. So when I rip the disc is there an easy way to separate them or am I fucked?
Grauhaar
Re: Blurays Having 5 Episodes As One File
#2 Post by Grauhaar » Fri May 25, 2018 10:22 am
Most Season Blu-rays have one Title (MPLS Playlist) which combines all Episodes on this disc (big size ~30-40GB). But there are normaly also Titles (MPLS Playlists) for each single Eposide (small Size ~10GB).
Good Luck :)
#3 Post by d00zah » Fri May 25, 2018 11:48 am
If the discs are authored with one, big title, mkvtoolnix will let you split on chapter/time boundaries. You'll need to figure out where the splits happen, but the tool does what you need.
#4 Post by Woodstock » Fri May 25, 2018 12:43 pm
Of course, if you process them with handbrake, you can split the episodes out AND have about a 75-80% reduction in the space taken up by the video, without noticeable degradation. Anime compresses VERY well.
