"Failed to open disc"
Waverley
Post by Waverley »
I'm having trouble creating an MKV from both DVDs in a two-part set. I get the same error. The disc is brand new but I have cleaned it anyway. It woks when I try to watch it in on my blu-ray player. Can anyone help making sense of the log? Thank you!
Debug log started at Tue May 22 16:03:07 2018 , written by MakeMKV v1.12.2 darwin(x64-release)
001005:0000 MakeMKV v1.12.2 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/......../MakeMKV_log.txt
002010:0000 Optical drive "BD-RE TSSTcorp BDDVDW SE-506CB TS02d" opened in OS access mode.
003028:0000 Title #1 was added (15 cell(s), 2:42:15)
DEBUG: Code 33554692 at Q-?[4W'q!#TYj"^;:213133526
Title skip vts=2 pgcn=1 hash=BF8BC3D3F35BF734
003025:0000 Title #3 has length of 6 seconds which is less than minimum title length of 60 seconds and was therefore skipped
003025:0000 Title #4 has length of 7 seconds which is less than minimum title length of 60 seconds and was therefore skipped
003025:0000 Title #5 has length of 10 seconds which is less than minimum title length of 60 seconds and was therefore skipped
001003:0020 DEBUG: Code 1 at Su8A4D?"M=vwq:213132445
001003:0020 DEBUG: Code 1 at Red!O]>RF a_d|@Ed+:213140702
001003:0020 DEBUG: Code 0 at v}}/z8kk;yJ=X61e:213140725
001003:0020 DEBUG: Code 0 at v}}/z8kk;yJ=X61e:213133756
001003:0020 DEBUG: Code 0 at v}}/z8kk;yJ=X61e:121273043
001003:0020 DEBUG: Code 0 at Red!O]>RF a_d|@Ed+:29408857
001003:0020 DEBUG: Code 1 at l+1e1eJyk$ZB1z@g:29394390
001003:0020 DEBUG: Code 0 at 'Iyslq &+E&t 9v:121270973
001003:0020 DEBUG: Code 0 at bYO/Z=Y. 6DGtv:213134883
Application exited at Tue May 22 16:47:19 2018
Re: "Failed to open disc"
First recommendation, since you've already cleaned the disks, is to follow the FAQ in my signature and send the requested files to support@makemkv.com for Mike to look at. Occasionally, a new trick shows up on DVDs, but it is rare.
