Gatekeeper High Sierra 10.13.4 never freely allows MakeMKV
nemike
Post by nemike »
No matter what I do I can not get gatekeeper to freely allow MakeMKV. Instead every time I run it I get the dialog that it is a downloaded application and I have to click on the open button on the dialog for it to actually allow MakeMKV to run. Anyone know how to solve this? I've even tried spctl --master-disable and it still pops up the dialog.
I've tried the following:
1. spctl --master-disable
2. spctl --add --label "MyApps" /PATH/To/MakeMKV.app
a. spctl --enable --label "MyApps"
3. Select open from the context menu on the icon for MakeMKV
Help this is driving me crazy!
Thanks, Mike
PS Anyone super familiar with mac's that can tell me TRUELY how to completely turn off gatekeeper??
T'hain Esh Kelch
Re: Gatekeeper High Sierra 10.13.4 never freely allows MakeM
Post by T'hain Esh Kelch »
Right click the MakeMKV binary in Finder, and select Open, and then say yes in the next dialog. GateKeeper shouldn't annoy you from then on with MakeMKV, until you update it. (That's what I do)
To turn off Gatekeeper completely, use the same as your command #1, but run it with sudo:
sudo spctl --master-disable
Alhtough, I would recommend you keep it on. Using the solution I wrote at the top, you can easily circumvent Gatekeeper in those few cases where it is needed.
nemike
Post by nemike »
In my original post I said I tried that in step #3, it didn't work. And neither did trying to turn off gatekeeper with "sudo spctl --master-disable"
Mike
