st4evr
#286
Post
by st4evr » Sat May 05, 2018 10:06 pm
paniyo wrote:This recorder is recommended for this program Buffalo BRUHD-PU3
In this page says that if Deuhd
Thank you
DeUHD and MakeMKV are two COMPLETELY different applications. No relation in development. What is supported by DeUHD may/will not necessarily work with MakeMKV.
Mike (MakeMKV developer) has explicitly provided us with a list of drives that may work with MakeMKV in the first post in this thread with instructions. It can’t be more clear that the drive you mention is not listed there.
jonghotti
Post
by jonghotti » Mon May 07, 2018 4:28 pm
I forget who was it that flashed the wh16ns60? And what service code was it?
These are on sale for $70 at Fry’s or 40% off.
Wondering if I should buy any.
ASUS there are two stores left wkthin 50 miles of me with Asus after that it’s so cal Texas and Georgia.
BH16NS40 are clearance status so they might be going away.
I’m mailing off 4 drives today to folks off this board and avs forum.
paniyo
#288
Post
by paniyo » Wed May 09, 2018 1:44 pm
st4evr wrote:paniyo wrote:This recorder is recommended for this program Buffalo BRUHD-PU3
Thank you
ok thanks for your response.
I will buy LG BE16NU50 with firmware works fine.
Thank you
st4evr
#289
Post
by st4evr » Wed May 09, 2018 2:52 pm
paniyo wrote:st4evr wrote:paniyo wrote:This recorder is recommended for this program Buffalo BRUHD-PU3
Thank you
Thank you
Official drives are NOT yet supported by MakeMKV. Mike has said they may be in the future. Until he updates the software to support the official drives on that list, you can ONLY use the UHD Friendly drives for UHD ripping.
EDIT: UNLESS, it supports cross-flashing to make it a UHD Friendly drive.
st4evr on Wed May 09, 2018 4:30 pm, edited 2 times in total.
jgirot
#290
Post
by jgirot » Wed May 09, 2018 4:11 pm
jonghotti wrote:I forget who was it that flashed the wh16ns60? And what service code was it?
You mean the other famous Italian? jgirot? SVC code: NS60, Mfr: June 2017, ROM Ver: 1.00
jonghotti wrote:These are on sale for $70 at Fry’s or 40% off.
That's up to you my friend. I've been told that there are still plenty of friendly drives out there. And the WH16NS60's require cross-flashing to be friendly. If there are friendly drives out there that only require down-grading to earlier f/w, that might be better than cross-flashing?!
jonghotti
Post
by jonghotti » Thu May 10, 2018 2:19 pm
jgirot wrote:jonghotti wrote:I forget who was it that flashed the wh16ns60? And what service code was it?
I meant Christopher Colombus, but you'll do
I just noticed this $198 HP Elite 8200 refurbished job has bios that'll allow you to boot into IDE mode. Hmmm.
Tico_RC
#292
Post
by Tico_RC » Thu May 10, 2018 10:09 pm
Hi guys
@TeddyRaspin gave me a hand with the Asus BW-16D1HT, and it worked amazingly well for a while
It doesn't work anymore though, even regular Blu-rays keep on spinning and rarely mount.. after that, multiple read problems (HARDWARE ERROR: TIMEOUT ON LOGICAL UNIT) which lead nowhere
Anybody else had this issues?
CR
Tico_RC
#293
Post
by Tico_RC » Thu May 10, 2018 10:14 pm
I bought a LG WH16NS40, firmware 1.03, manufactured March 2018
I spits the discs out. Will the same firmware mod procedure on the Asus BW-16D1HT apply to LG WH16NS40?
I read posts about 1.02 but found nothing about 1.03
Any experience with this one?
#294
Post
by d00zah » Thu May 10, 2018 10:35 pm
Tico_RC wrote:I bought a LG WH16NS40, firmware 1.03, manufactured March 2018
Got the same drive last week w/ 1.03, which closes the necessary 'loophole'.
Downgraded using bootable USB drive per the instructions detailed here:
http://www.makemkv.com/forum2/viewtopic ... 058#p60312
jonghotti
Post
by jonghotti » Fri May 11, 2018 1:58 am
Remember if you want a sure thing hit me up!
(that sounded odd, but I'm sure you know what I mean)
paniyo
#296
Post
by paniyo » Mon May 21, 2018 2:16 pm
I got LG BE16NU50.Version 1.02
makemkv tells me there is no disc
what am I missing
what am I doing wrong
Thank you
#297
Post
by Woodstock » Mon May 21, 2018 3:21 pm
If it shows the Service Code of NS50 or higher, it should read UHD disks, at least to the point of being able to show the disk being loaded.
paniyo
#298
Post
by paniyo » Mon May 21, 2018 4:35 pm
this is what appears to me
open and close and nothing
begins to start and leaves the image
Woodstock wrote:If it shows the Service Code of NS50 or higher, it should read UHD disks, at least to the point of being able to show the disk being loaded.
- lg.jpg (133.09 KiB) Viewed 35267 times
paniyo on Mon May 21, 2018 4:49 pm, edited 5 times in total.
jonghotti
Post
by jonghotti » Mon May 21, 2018 4:36 pm
paniyo wrote:I got LG BE16NU50.Version 1.02
what am I missing
Thank you
Sorry about that, a picture of the sticker on the back if you would please.
jonghotti on Mon May 21, 2018 4:50 pm, edited 1 time in total.
paniyo
#300
Post
by paniyo » Mon May 21, 2018 4:45 pm
so I do not know what you're asking me
sorry but I'm little put in this topic
I do not know exactly what you're asking me
I am a beginner
