1.5.6 fails on "Girl With the Dragon Tattoo"
farmwald
#1 Post by farmwald » Wed Jul 07, 2010 10:47 pm
MakeMKV 1.5.6 (windows) fails on "Girl With the Dragon Tattoo".
Movie was ripped with AnyDVD - plays fine.
Opening files on harddrive at R:/Backups/Netflix 12/GIRL_WITH_THE_DRAGON_TATTOO/
AACS directory not present, assuming unencrypted disc
File 00000.m2ts was added as title #0
Title #00001.m2ts has length of 10 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00002.m2ts has length of 8 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00004.m2ts has length of 99 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00005.m2ts has length of 118 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00006.m2ts has length of 103 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00007.m2ts has length of 105 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00008.m2ts has length of 88 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00009.m2ts has length of 139 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00010.m2ts has length of 150 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00011.m2ts has length of 150 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00014.m2ts has length of 103 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00015.m2ts has length of 60 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00016.m2ts has length of 751 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00017.m2ts has length of 4 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00018.m2ts has length of 4 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00020.m2ts has length of 82 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Operation sucessfully completed
Saving 1 titles into directory R:/Video/Vtmp/MakeMKV/Girl With the Dragon Tattoo
DEBUG: Code 0 at ^G)jDnTaThp%3DSZdyTe:213130973
DEBUG: Code 0 at C-5>Jj|SP,<E-*NgtH+m:29394413
DEBUG: Code 1582074 at C-5>Jj|SP,<E-*NgtH+m:213129639
Failed to save title 0 to file R:/Video/Vtmp/MakeMKV/Girl With the Dragon Tattoo/title00.mkv
0 titles saved, 1 failed
setarip_old
Re: 1.5.6 fails on "Girl With the Dragon Tattoo"
#2 Post by setarip_old » Thu Jul 08, 2010 1:43 am
Hi!
1) Exit and completely turn off AnyDVD
2) Use MakeMKVto rip the ORIGINAL disc DIRECTLY to .MKV or,
3) First use MakeMKV's "Backup" function to make a full disc copy of your original, purchased BluRay disc to your hard drive and then use MakeMKV to convert this new backup to .MKV
BTW - Although it shouldn't have any effect regarding BluRays (But may affect DVD ripping), the proper default setting for "minimum title length" is 120 seconds, not 1200 seconds.
#3 Post by mike admin » Thu Jul 08, 2010 6:42 am
Looks like a bad decryption. The full log contains additional information, the "tp=" line. This information is needed to troubleshoot. I would only recommend re-running on original disc.
farmwald
#4 Post by farmwald » Thu Jul 08, 2010 8:08 pm
Thanks for the help.
Reading the disk directly with MakeMKV worked.
I was curious what happened with AnyDVD, so I tried some experiments. After some confusing results, I finally re-ripped with ANyDVD and (I think) the same settings as originally - but the rerip works fine with MakeMKV while the first rip fails. I probably did something wrong the first time - most likely hit the wrong button for region.
In case anyone is interested, here is the failing log:
Debug log started at Thu Jul 08 19:23:56 2010 , written by MakeMKV v1.5.6 beta win(x64-release)
001005:0000 MakeMKV v1.5.6 beta win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Mike Farmwald/MakeMKV_log.txt
003006:0000 Opening files on harddrive at F:/GIRL_WITH_THE_DRAGON_TATTOO/
DISCID=FB82E67F7256BF67915C75E07946C3D545E51C7B
003307:0000 File 00000.m2ts was added as title #0
003025:0000 Title #00001.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00009.m2ts was added as title #1
003307:0000 File 00010.m2ts was added as title #2
003307:0000 File 00011.m2ts was added as title #3
003025:0000 Title #00014.m2ts has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00016.m2ts was added as title #4
003025:0000 Title #00017.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory J:/Video/Orig (fails)
002008:0020 Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
tp=Poir6Axrz65Qh//a4VmPcLSsC+nz+/v7+/v7+/gtFkoJHEBERjEX4byu9bjJ22VkKPYBb1LllMIMNBxFHm8ZSpwc2QItCXRLmdzE3P18+vAEoqd2uL+a4mqGuwaCnl91rNXqM35rIxlFldEXL+Cagw7hIOgIoSRrv+EjC7K+507A0AFfzsbzx/HeqGtDD2/6LI46r4lXCAHq7owZyDpo/JUGR9kATos4IdA4NzEdMqTcS2ycFmGj8AGsJOWk=
001003:0020 DEBUG: Code 0 at ^G)jDnTaThp%3DSZdyTe:213130973
tp=PSWJiK6Iq+gMa8+uUIf/2uFZj3C0rAvp8/v7+/v7+/v4LRZKCRxAREYxF+G8rvW4ydtlZCj2AW9S5ZTCDDQcRR5vGUqcHNkCLQl0S5ncxNz9fPrwBKKndri/muJqhrsGgp5fdazV6jN+ayMZRZXRFy/gmoMO4SDoCKEka7/hIwuyvudOwNABX87G88fx3qhrQw9v+iyOOq+JVwgB6u6MGcg6aPyVBkfZAE6LOCHQODcxHTKk3EtsnBZho/ABrCTlp
ts0=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
001003:0020 DEBUG: Code 0 at C-5>Jj|SP,<E-*NgtH+m:29394413
001003:0020 DEBUG: Code 1582074 at C-5>Jj|SP,<E-*NgtH+m:213129639
001003:0020 DEBUG: Code 0 at 4W};L;r&^?Gm&V34bo}KC:29397449
005003:0000 Failed to save title 0 to file J:/Video/Orig (fails)/title00.mkv
005004:0080 0 titles saved, 1 failed
setarip_old
#5 Post by setarip_old » Fri Jul 09, 2010 1:39 am
Glad to her that my suggestion worked for you ;>}
jimx1169
#6 Post by jimx1169 » Sun Jul 25, 2010 6:34 pm
You may also try not ripping your Netflix rentals as it's not legal.
setarip_old
#7 Post by setarip_old » Sun Jul 25, 2010 10:48 pm
@jimx1169
Hi!
I guess you missed the red highlighting in my first post to this thread 17 days ago. There are many ways to signal the moderators - and let them decide whether to pursue such things - and on the very same day, "mike admin" posted to this thread and chose not to pursue the "Netflix" aspect.
Perhaps once they get around to formally posting the Forum rules, such activity will be clearly indicated as being unacceptable for posting (although it's actually legal in some countries, the rules of this private forum will prevail here, just as they do at other forums)...
