Build failure with GCC 8? (Fedora 28)
hobbes1069
Post by hobbes1069 »
Had it building fine on Fedora 27 w/ GCC 7 but now I get this:
libffabi/src/ffabi.c: In function 'ffm_audio_encode_init':
libffabi/src/ffabi.c:520:30: error: 'CODEC_FLAG_GLOBAL_HEADER' undeclared (first use in this function); did you mean 'AV_CODEC_FLAG_GLOBAL_HEADER'?
         ctx->avctx->flags |= CODEC_FLAG_GLOBAL_HEADER;
libffabi/src/ffabi.c:520:30: note: each undeclared identifier is reported only once for each function it appears in
libffabi/src/ffabi.c: In function 'ffm_audio_encode_get_info':
libffabi/src/ffabi.c:721:28: error: 'CODEC_FLAG_GLOBAL_HEADER' undeclared (first use in this function); did you mean 'AV_CODEC_FLAG_GLOBAL_HEADER'?
     if ((ctx->avctx->flags&CODEC_FLAG_GLOBAL_HEADER)!=0)
Thanks,
Richard
chowbok
Re: Build failure with GCC 8? (Fedora 28)
Post by chowbok »
The problem isn't GCC, it's that libavformat just updated and a variable name changed. Here's a diff:
*** makemkv-oss-1.12.2/libffabi/src/ffabi.c.ORIG	2018-04-27 20:53:47.000000000 -0500
--- makemkv-oss-1.12.2/libffabi/src/ffabi.c	2018-05-13 09:11:26.215809333 -0500
*** 517,523 ****
          info->profile : FF_PROFILE_UNKNOWN;
      if ((CodecFlags&FFM_CODEC_FLAG_GLOBAL_HEADER)!=0)
!         ctx->avctx->flags |= CODEC_FLAG_GLOBAL_HEADER;
      if (argp) {
          for (i=0;argp[i];i+=2) {
--- 517,523 ----
!         ctx->avctx->flags |= AV_CODEC_FLAG_GLOBAL_HEADER;
      if (argp) {
*** 718,724 ****
      info->delay = (int32_t)ctx->avctx->delay;
      info->flags = 0;
!     if ((ctx->avctx->flags&CODEC_FLAG_GLOBAL_HEADER)!=0)
          info->flags |= FFM_CODEC_FLAG_GLOBAL_HEADER;
      return 0;
--- 718,724 ----
      info->flags = 0;
!     if ((ctx->avctx->flags&AV_CODEC_FLAG_GLOBAL_HEADER)!=0)
      return 0;
Apply that and it should compile okay.
Zontar
Post by Zontar »
The patch allows it to compile, but I get an error "Application failed to initialize" when I try and launch it.
Zontar
Post by Zontar »
I reinstalled Fedora 28 from scratch. That helped a lot. The series of upgrades left a bunch of cruft that made compiles not work correctly. (Like ldconfig database containing old information that no longer existed.)
wdomburg
Post by wdomburg »
This looks to be due to an upgrade to ffmpeg 4.0, which versions it's libraries as .58. Fedora 27 was on ffmpeg 3.3, which is .57. Unfortunately there is only a compat library for ffmpeg 2.8, which is .56.*
Not sure there is a simple workaround here until a new makemkv-bin with makemkvconv linked against the new library is released or a compat-ffmpeg33 package is added to the repo. I may just build my own if I have to. :)
* I'm using the rpmfusion repo. Not sure if there are any alternate repos worth using these days.
papastuck
Post by papastuck »
The diff from chowbok worked for me on Debian Unstable.
alexb0000
Post by alexb0000 »
chowbok wrote:The problem isn't GCC, it's that libavformat just updated and a variable name changed. Here's a diff:
*** 517,523 ****
      if (argp) {
--- 517,523 ----
      if (argp) {
*** 718,724 ****
      info->flags = 0;
      return 0;
--- 718,724 ----
      info->flags = 0;
      return 0;
This worked for me on Fedora 28, thanks.
