No SVC Code?
Anthony1017
No SVC Code?
Post by Anthony1017 » Fri May 18, 2018 6:43 pm
Hello newb here to all this uhd ripping stuff, Been doing research on what drives work to rip uhd movies.
I have an LG WH14NS40 2012 Rom Ver 1.0 that rips blurays but its unable to see uhd discs, I looked on the drive and it doesn't have a svc label anywhere on it.
Im guessing its not compatible with uhd discs correct?
st4evr
Re: No SVC Code?
Post by st4evr » Fri May 18, 2018 6:50 pm
That is correct. The requirements are there for a reason and has to be the correct Service Code.
Anthony1017
Re: No SVC Code?
Post by Anthony1017 » Fri May 18, 2018 6:52 pm
st4evr wrote:That is correct. The requirements are there for a reason and has to be the correct Service Code.
Ok thanks that's what i needed to know
