Loading a backup in MakeMKV
garbage
Post by garbage »
Hi, I made a backup of a UHD BD using the provided backup function in MakeMKV. Now I have an folder containing three subfolders BDMV, CERTIFICATE and MAKEMKV. I made sure to check to decrypt option before proceeding and now I assume that these folders represent the decrypted data structure of the entire disk. Is this correct?
However, now I am wondering how can I load these data structure back in MakeMKV to generate an MKV file? Under the open disk command I only can select my drive which is is empty of course. I can't find any kind of importing command in the command bar.
How can I reload a generated disc backup in MakeMKV?
Thanks for your support!
Re: Loading a backup in MakeMKV
Look for the file index.bdmv in the directory BDMV; File->Open Files, navigate to index.bdmv, and hit enter.
garbage
Post by garbage »
Thanks! :mrgreen:
