makemkv hangs when starting up
gamestar
#1 Post by gamestar » Sun Apr 05, 2009 1:48 am
When I start makemkv, I see scanning device: SPT1\:Device\CdRom0 under information but that's all. It never goes any further and all the options under File are grayed out. I saw some other posts talking about a problem with having SATA set to AHCI but I"ve verified in BIOS that it is set to IDE. I"ve installed it on my main PC and it works fine so it has something to do with this machine. I have a Pioneer Blu-Ray drive and a Asus P5Q-EM motherboard. I"ve had it running while typing this post and it is currently at 9:03 and still scanning. Any idea what could be the problem?
Re: makemkv hangs when starting up
#2 Post by mike admin » Sun Apr 05, 2009 9:55 am
We've never seen such hung. What OS are you running?
gamestar
#3 Post by gamestar » Sun Apr 05, 2009 5:20 pm
I'm running Vista home premium.
gamestar
#4 Post by gamestar » Tue Apr 14, 2009 4:58 pm
Any ideas on this problem? I've downloaded v1.4.1 and still having the same issue.
Also, I was unable to convert the movie Signs. This is a standard DVD, not HD. I can't remember what the error was but I can get it for you when I get home. Also, just so you know, I'm using makemkv against files stored on my computer and not the actual DVD. I've already ripped my DVDs to harddrive using DVDShrink to rip the main movie only and store it in standard DVD format. I'm using makemkv to convert them to mkv format. I've done about 50 so far and this is the only one that's been a problem.
Finally, I have several titles (mostly music videos) with audio in LPCM format. I saw in the post on doom9 that you plan to support that at some point. I was just wondering if this is something that's actively being worked on or is it more like something to be done eventually when time permits?
Thanks.
gamestar
#5 Post by gamestar » Tue Apr 14, 2009 7:47 pm
OK, now I have 2 that failed. Here's what's shown in the bottom window for each:
Signs
Opening files on harddrive at I:/Movies/Signs/VIDEO_TS/
Cell 24 was discarded (structure protection?)
Title #0 was added (23 cell(s), 1:45:48)
Operation sucessfully completed
Saving 1 titles into directory I:/Movies/Signs
LIBMKV_TRACE: Exception: MKV_ASSERT: (m_MarksCount==m_ChapterMarks.size()) || ((m_MarksCount+1)==m_ChapterMarks.size())
Failed to save title 0 to file I:/Movies/Signs/title00.mkv
0 titles saved, 1 failed
Unbreakable:
Opening files on harddrive at C:/Documents and Settings/All Users/Documents/newpc/Movies/Unbreakable/VIDEO_TS/
Title #0 was added (35 cell(s), 1:45:30)
Saving 1 titles into directory C:/Documents and Settings/All Users/Documents/newpc/Movies/Unbreakable
Failed to save title 0 to file C:/Documents and Settings/All Users/Documents/newpc/Movies/Unbreakable/title00.mkv
#6 Post by mike admin » Thu Apr 16, 2009 9:54 am
Problem noted.
gamestar
#7 Post by gamestar » Sun Apr 19, 2009 4:29 pm
I tried converting the Signs DVD using mkvmerge and got the following warning. I don't know if this has anything to do with makemkv having a problem with this title.
Warning: 'C:\SIGNS\VIDEO_TS\VTS_01_1.VOB' track 1: This AC3 track contains 1120 bytes of non-AC3 data which were skipped. The audio/video synchronization may have been lost.
mongo
#8 Post by mongo » Mon Jun 15, 2009 4:26 pm
gamestar wrote:When I start makemkv, I see scanning device: SPT1\:Device\CdRom0 under information but that's all. It never goes any further and all the options under File are grayed out. I saw some other posts talking about a problem with having SATA set to AHCI but I"ve verified in BIOS that it is set to IDE. I"ve installed it on my main PC and it works fine so it has something to do with this machine. I have a Pioneer Blu-Ray drive and a Asus P5Q-EM motherboard. I"ve had it running while typing this post and it is currently at 9:03 and still scanning. Any idea what could be the problem?
I have exactly the same problem...
Running Win XP, SATA is set to IDE, Pioneer Bluray and also a Asus motherboard.
Looks like Any-dvd crashes att the same time, and my computer stops responding.
Any ideas?
homerzero
#9 Post by homerzero » Wed Jun 17, 2009 12:45 pm
gamestar wrote:When I start makemkv, I see scanning device: SPT1\:Device\CdRom0 under information but that's all. It never goes any further and all the options under File are grayed out. I saw some other posts talking about a problem with having SATA set to AHCI but I"ve verified in BIOS that it is set to IDE Any idea what could be the problem?
i have the same problem this morning (stalling when scanning cd devices ) MakeMKV was running fine yesterday . i am running win XP sp3 .i have even done a repair install of windows Xp and MakeMKV still stalls .
#10 Post by mike admin » Fri Jun 19, 2009 5:40 am
This is not good, but I can't see what can be done to identify the problem. Does it happen regardless of the disc inserted?
heistruett
#11 Post by heistruett » Thu Sep 17, 2009 12:11 pm
Same problem:
Scanning device: SPTI:\Device\CdRom0 ...
System: all AMD
4850e, Gigabyte GA790, Harddisks driven in RAID5 Mode (Chipset Promise RAID), so I cannot change the Bios Settings for Sata-Rom DRive, Pioneer 216
no BluRay device, BluRay was ripped to file tructure at a service station
BS: Windows 7 RC 7100, 64-bit
MakeMKV: 1.4.6
two visible processes:
makemkv.exe *32, 0% CPU
makemkvcon.exe *32 0% CPU
Canceling makemkv quits only makemkv.exe, makemkvcon.exe remains.
Sarting and stopping makemkv several times recieves several processes makemkvcon.exe staying in memory and waiting for the great blow...
