Asus 3.02 firmware
cbnbmore
Asus 3.02 firmware
Post by cbnbmore » Sun Feb 11, 2018 3:55 pm
Just wanted to be sure. The 3.02 firmware is the last safe firmware to use for the Asus 16HT correct? 3.03 will make the drive unfriendly?
TeddyRaspin
Re: Asus 3.02 firmware
Post by TeddyRaspin » Sun Feb 11, 2018 4:09 pm
Yes. 3.02 is OK, 3.03 NOT. :wink:
pimpinonline
Post by pimpinonline » Wed May 09, 2018 2:58 pm
I'm on 3.01, is there any reason to upgrade to 3.02?
st4evr
Post by st4evr » Wed May 09, 2018 3:08 pm
pimpinonline wrote:I'm on 3.01, is there any reason to upgrade to 3.02?
You should search the forum or read through this thread first.
http://www.makemkv.com/forum2/viewtopic ... 8&start=45
hdmkv
Post by hdmkv » Fri May 11, 2018 7:52 pm
I'm on 3.00 with two Asus drives and have had zero issues w/rips and speeds.
GadgetMan
Post by GadgetMan » Fri May 11, 2018 8:18 pm
I have just received a brand new Asus BW-16D1HT drive. According to Makemkv it has firmware 3.02.
I saved the hash keys file from here (http://s000.tinyupload.com/index.php?fi ... 8006246024) in my Makemkv data directory.
However, which ever UHD disk I try all I get is "Loading..." for about 10 seconds with the blue flashing light and a spinning disc on the drive icon and then the spinning disc disappears Makemkv says "No disc"
So far I have tried UHDs for Unforgiven, Joy, Wonderwoman and Deadpool - all of which have at least one entry in the keys file.
I have had Makemkv for a while but have never used it before, as previously I have just used handbrake with my 1080p blurays, so I could well be doing something dumb.
(I tried a bluray just to make sure that the new drive was OK and Makemkv opened that.)
The information displayed by Makemkv is as below and there is nothing in the debug log other than a line about starting the debug file.
Does anyone have any suggestions?
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Serial number: XXXXXXX
Firmware date: 2117-11-15 17:16:
Bus encryption flags: 1F
Highest AACS version: 63
MakeMKV v1.12.2 win(x64-release) started
st4evr
Post by st4evr » Fri May 11, 2018 11:44 pm
GadgetMan wrote:I have just received a brand new Asus BW-16D1HT drive. According to Makemkv it has firmware 3.02.
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
This issue has already been discussed across multiple threads for some time. Including the link I provided in my post above.
Another example:
http://www.makemkv.com/forum2/viewtopic ... .02#p61880
GadgetMan
Post by GadgetMan » Sat May 12, 2018 6:12 pm
st4evr wrote: This issue has already been discussed across multiple threads for some time. Including the link I provided in my post above.
Another example:
Thanks very much for that st4evr. I had read around a bit and thought that drives with firmware 3.02 did not have an issue but I see now that is not the case.
I have just ordered a used drive with firmware 1.?? and will upgrade that.
I assume that it is safe for me to simply download the version 3.01 or 3.02 firmware from these forums (from the links below) and simply install one of those on the new drive.
http://makemkv.com/forum2/download/file.php?id=1252
http://makemkv.com/forum2/download/file.php?id=1235
I will send back the new drive that i had bought as I don't have a spare PC for going through the firmware downgrade process.
st4evr
Post by st4evr » Sun May 13, 2018 12:20 am
If you mean an Asus drive with firmware 1.xx, then you need to do some more reading/research:
http://www.makemkv.com/forum2/viewtopic ... 015#p61787
Again, that scenario already discussed and attempted as well.
GadgetMan
Post by GadgetMan » Sun May 13, 2018 5:35 pm
st4evr wrote:If you mean an Asus drive with firmware 1.xx, then you need to do some more reading/research:
Damn! Looks like my new drive will be going straight in the bin.
Getting a new UHD friendly drive is more difficult than I thought.
I cannot downgrade my new drive as I don't have a spare old PC to do that.
I wonder if there is anywhere I can buy an appropriate drive from in the UK?
andfull
Post by andfull » Sat May 19, 2018 3:08 pm
Yes, brought BW16D1HT this week from http://cclonline.com; manufactured in may 2016 with v. 3.0. Works fine.
MaDMaX**
Post by MaDMaX** » Wed May 23, 2018 9:25 am
hi ya, thanks for updating this thread, like yourself im a bit late to this game, but might take a punt on that drive from ccl, have you mounted yours externally or are you using it as an internal drive, i only have a laptop to use, so would need to put it in a case
Dickoto
Post by Dickoto » Thu Jul 03, 2025 12:21 pm
Hey! No worries, better late than never 😄 I was in the same boat — just recently jumped in myself. I went ahead and mounted mine externally using a USB 3.0 enclosure since I’m mostly working off a laptop too. It’s been working great for backups and game storage, and honestly, way easier than trying to rig something internal without a desktop.
If you're still shopping around, you might want to check out PC International — they’ve got a decent selection of enclosures and drives, often at better prices than the usual big sites. I found a few good deals there when I was piecing together my setup.
Let us know what you go with in the end!
