Saving Private Ryan UHD
maddog510
#1 Post by maddog510 » Sat May 12, 2018 3:51 pm
I think this is a 1st for me but when I ripped Saving Private Ryan last night, it shows it has 2 seperate video files. This is what it indicates in Plex;
Codec HEVC
Bitrate 52120 kbps
Bit Depth 10
Chroma Subsampling 4:2:0
Color Primaries bt2020
Color Range tv
Color Space bt2020nc
Color Trc smpte2084
Frame Rate 23.976 fps
Height 2160
Level 5.1
Profile main 10
Ref Frames 1
Width 3840
Forced true
Codec HEVC
Bitrate 5797 kbps
Bit Depth 10
Color Range tv
Color Trc smpte2084
Height 1080
Level 5.1
Profile main 10
Ref Frames 1
Width 1920
Usually it shows just 1 bitrate for the video but here it shows 2 & more importantly why is it showing 1080p on a 4K disc?
st4evr
Re: Saving Private Ryan UHD
#2 Post by st4evr » Sat May 12, 2018 4:48 pm
Dolby Vision layer:
https://www.google.com/search?client=fi ... 4b_LF32DR0
