Win7 x64 Killed by "Complex multiplex encountered"
kwanbis
Post by kwanbis » Tue Jul 06, 2010 3:54 am
I have one DVD on my HD, that at some points, it says:
Complex multiplex encountered - 8 cells and 4928 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Then, instead of going to 4928, MakeMKV goes to 2 million something, and it kills Windows 7, 64 bits, at a point where i have no more options to turn off the machine.
Any ideas?
setarip_old
Re: Win7 x64 Killed by "Complex multiplex encountered"
Post by setarip_old » Tue Jul 06, 2010 6:23 am
Hi!
1) What is the title and region of your original, commercial DVD?
2) Use MakeMKV DIRECTLY with your original, commercial DVD
Post by mike admin » Tue Jul 06, 2010 6:35 am
kwanbis wrote:Then, instead of going to 4928, MakeMKV goes to 2 million something, and it kills Windows 7, 64 bits, at a point where i have no more options to turn off the machine.
Wow. Please send ifo files per http://www.makemkv.com/faq/item/8/catid/6
kwanbis
Post by kwanbis » Tue Jul 06, 2010 12:53 pm
I just sent you the files.
I had to quit MakeMKV, cause cancelling the part where it breaks, would not work, and it only gives me some seconds till it crashes W7.
kwanbis
Post by kwanbis » Tue Jul 06, 2010 1:00 pm
EDIT: WOW, even if closed MakeMKV, i had to turn off the machine, as W7 started to not respond!
setarip_old
Post by setarip_old » Tue Jul 06, 2010 1:13 pm
Did you try using MakeMKV DIRECTLY with your original, commercial DVD?
kwanbis
Post by kwanbis » Tue Jul 06, 2010 1:18 pm
I actually store my originals on a friends house, and have the backups with me (he does the same), just in case.
I would need to get them, but not possible that quick.
setarip_old
Post by setarip_old » Wed Jul 07, 2010 6:10 pm
So, what is the title and region of the DVD?
I and/or other members may have the same release and may be able to compare...
kwanbis
Post by kwanbis » Wed Jul 07, 2010 9:00 pm
The dvd is called "Las Mu?ecas de la Mafia", is the 1st DVD, is a colombian TV series.
By the way, VOB2MPG was able to process it without issues.
