Files in 576i not 1080p
drandy
Post by drandy » Fri May 11, 2018 10:12 am
I am new to all this and just setting up a home cinema using a Plex media server
When I save the maker Kev file to the Plex server it says they are in 576i not 1080p.
What am I doing wrong?
Grauhaar
Re: Files in 576i not 1080p
Post by Grauhaar » Fri May 11, 2018 10:51 am
What have you ripped with MakeMKV? A DVD has 576i (maximal), only Blu-rays have a maximum resolution of 1080p or other lower resolution formats.
Good Luck :)
drandy
Post by drandy » Fri May 11, 2018 11:16 am
Thanks! I new to all this and always thought dvds were 1080p!
Learn something new every day!
Post by Woodstock » Fri May 11, 2018 3:01 pm
DVD is "480i", or "576i" if it is a PAL DVD. Through use of anamorphic (non-square pixels), it can achieve a wider aspect ratio, but the maximum resolution is 720 wide.
