UHD drives
Locked
st4evr
Re: UHD drives
Post by st4evr »
paniyo wrote:This recorder is recommended for this program Buffalo BRUHD-PU3
In this page says that if Deuhd
Thank you
DeUHD and MakeMKV are two COMPLETELY different applications. No relation in development. What is supported by DeUHD may/will not necessarily work with MakeMKV.
Mike (MakeMKV developer) has explicitly provided us with a list of drives that may work with MakeMKV in the first post in this thread with instructions. It can’t be more clear that the drive you mention is not listed there.
jonghotti
Re: UHD drives
Post by jonghotti »
I forget who was it that flashed the wh16ns60? And what service code was it?
These are on sale for $70 at Fry’s or 40% off.
Wondering if I should buy any.
ASUS there are two stores left wkthin 50 miles of me with Asus after that it’s so cal Texas and Georgia.
BH16NS40 are clearance status so they might be going away.
I’m mailing off 4 drives today to folks off this board and avs forum.
paniyo
Re: UHD drives
Post by paniyo »
Thank you
ok thanks for your response.
I will buy LG BE16NU50 with firmware works fine.
Thank you
st4evr
Re: UHD drives
Post by st4evr »
Thank you
Thank you
Official drives are NOT yet supported by MakeMKV. Mike has said they may be in the future. Until he updates the software to support the official drives on that list, you can ONLY use the UHD Friendly drives for UHD ripping.
EDIT: UNLESS, it supports cross-flashing to make it a UHD Friendly drive.
jgirot
Re: UHD drives
Post by jgirot »
jonghotti wrote:I forget who was it that flashed the wh16ns60? And what service code was it?
You mean the other famous Italian? jgirot? SVC code: NS60, Mfr: June 2017, ROM Ver: 1.00
jonghotti wrote:These are on sale for $70 at Fry’s or 40% off.
That's up to you my friend. I've been told that there are still plenty of friendly drives out there. And the WH16NS60's require cross-flashing to be friendly. If there are friendly drives out there that only require down-grading to earlier f/w, that might be better than cross-flashing?!
jonghotti
Re: UHD drives
Post by jonghotti »
I meant Christopher Colombus, but you'll do ;-)
I just noticed this $198 HP Elite 8200 refurbished job has bios that'll allow you to boot into IDE mode. Hmmm.
Tico_RC
Re: UHD drives
Post by Tico_RC »
Hi guys
@TeddyRaspin gave me a hand with the Asus BW-16D1HT, and it worked amazingly well for a while
It doesn't work anymore though, even regular Blu-rays keep on spinning and rarely mount.. after that, multiple read problems (HARDWARE ERROR: TIMEOUT ON LOGICAL UNIT) which lead nowhere
Anybody else had this issues?
CR
Tico_RC
Re: UHD drives
Post by Tico_RC »
I bought a LG WH16NS40, firmware 1.03, manufactured March 2018
I spits the discs out. Will the same firmware mod procedure on the Asus BW-16D1HT apply to LG WH16NS40?
I read posts about 1.02 but found nothing about 1.03
Any experience with this one?
Re: UHD drives
Post by d00zah »
Tico_RC wrote:I bought a LG WH16NS40, firmware 1.03, manufactured March 2018
Got the same drive last week w/ 1.03, which closes the necessary 'loophole'.
Downgraded using bootable USB drive per the instructions detailed here:
http://www.makemkv.com/forum2/viewtopic ... 058#p60312
jonghotti
Re: UHD drives
Post by jonghotti »
Remember if you want a sure thing hit me up!
(that sounded odd, but I'm sure you know what I mean)
paniyo
Re: UHD drives
Post by paniyo »
I got LG BE16NU50.Version 1.02
makemkv tells me there is no disc
what am I missing
what am I doing wrong
Thank you
Re: UHD drives
If it shows the Service Code of NS50 or higher, it should read UHD disks, at least to the point of being able to show the disk being loaded.
paniyo
Re: UHD drives
Post by paniyo »
this is what appears to me
open and close and nothing
begins to start and leaves the image
Woodstock wrote:If it shows the Service Code of NS50 or higher, it should read UHD disks, at least to the point of being able to show the disk being loaded.
jonghotti
Re: UHD drives
Post by jonghotti »
paniyo wrote:I got LG BE16NU50.Version 1.02
what am I missing
Thank you
Sorry about that, a picture of the sticker on the back if you would please.
paniyo
Re: UHD drives
Post by paniyo »
so I do not know what you're asking me
sorry but I'm little put in this topic
I do not know exactly what you're asking me
I am a beginner
Locked
