Hello
Sorry for my English I'm Spanish.
I need help.
I bought this recorder Pioneer Bdr-Xd07J
I do not know how the program is used.
I want it is an exact copy of the original movie that I have
I install the latest version I press backup I get a lot of errors.
If I press where the mouse is.
Someone can explain step by step how to do it.
I also do not know where I have to put Hashed Keys exactly.
There are also people who have this file "keydb.cfg" I do not know what it is
This is error:
"The error occurred 'SCSI Error - ILLEGAL REQUEST: COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' sending the SCSI command AD010..080002400 to the device 'SPTI: \ Device \ CdRom0'
The AACS VID on the disk can not be read - probably the disk drive has revoked the AACS host certificate
AACS dump file saved as D: /uhd/MKB20_v61_Dunkirk_7EFD.tgz
The volume key of this disc is unknown. Unable to decrypt the video
Failed to open the disk "
I beg you to help me
Thank you very much
I do not work makemkv
- 1.jpg (1.08 MiB) Viewed 20920 times
Re: I do not work makemkv
I believe that your drive is not UHD friendly. I'm pretty sure that no Pioneer drives are UHD friendly. Your Pioneer Bdr-Xd07J is an official UHD drive which is not compatible at the moment.
According to DeUHD's website, the non-official UHD friendly drives are:
LG BE16NU50
LG WH16NS40 (SVC code: NS50)
LG BH16NS40 (SVC code: NS50)
ASUS BW-12B1ST
ASUS BC-12D2HT
ASUS BW-16D1HT a
LG BH16NS55
LG WH16NS58
ASUS BW-16D1H-U A201
LG BU30N
LG BE16NU50
ASUS BW-12B1ST
ASUS BC-12D2HT
ASUS BW-16D1HT a
LG BH16NS55
LG WH16NS58
LG BU30N
What a disappointment.MartyMcNuts wrote:I believe that your drive is not UHD friendly. I'm pretty sure that no Pioneer drives are UHD friendly. Your Pioneer Bdr-Xd07J is an official UHD drive which is not compatible at the moment.
LG BE16NU50
ASUS BW-12B1ST
ASUS BC-12D2HT
ASUS BW-16D1HT a
LG BH16NS55
LG WH16NS58
LG BU30N
Buy this unit thinking it was the best option to burn the discs uhd 4k
"Exact copy of the disk" is not a feature MakeMKV claims.
It can create a "backup" of the disk's contents, but that does not contain everything necessary to copy the disk.
This recorder is recommended for this program Buffalo BRUHD-PU3
In this page says that if https://www.deuhd.ru/supported.html
Thank you
Thank you
In this page says that if Deuhd
Thank you
Thank you
