Hostiles correct playlist
JediSamReye
Post by JediSamReye » Tue Apr 24, 2018 2:27 pm
Hello all! I just installed run time environment to get this going. If anyone needs the red playlist it is Segment map: 511,501,506,513,508,512,507,503,510,515,502,514,505,504,509
chadjamesr
Re: Hostiles correct playlist
Post by chadjamesr » Tue Apr 24, 2018 5:11 pm
I find the segment map to be the same and the source file name to be 00208.mpls.
bretb
Post by bretb » Wed Apr 25, 2018 1:33 am
Tayvl
Post by Tayvl » Wed Apr 25, 2018 11:03 am
Thanks for the info, folks.
UsedKondomXL
Post by UsedKondomXL » Wed May 02, 2018 8:24 am
How do you get MakeMKV to tell you that one is the Main Feature ? I installed the Java JRE and pointed at it in the preferences but still nothing.
Grauhaar
Post by Grauhaar » Wed May 02, 2018 9:10 am
There is no need to specify Java in the preferences. MakeMKV find the standard Java implementation. This option is only to specify a special Java implementation.
If MakeMKV needs Java you shoud see these messages in the log:
Found java version=1.8.0.171 path=C:\Program Files\Java\jre1.8.0_171\bin\java.exe
Found java version=1.8.0.171 path=C:\Program Files (x86)\Java\jre1.8.0_171\bin\java.exe
003344:0000 Using Java runtime from C:\Program Files\Java\jre1.8.0_171\bin\java.exe
To check if Java is overall accessible open a "DOS Window" and type "Java -version". You should now see the java version information.
Good Luck :)
