I think you mean the 3.02 firmware ... some people have reported that the 3.02 firmware did not work for them as it patched the ACCS hole. Your best bet will be to install it in your PC and then use makemkv to read a UHD disc. If it is successful to rip the disc, you are golden. If not you will need to use Teddy's procedure to make a dump of your existing firmware using DOSFLASH and use the EEPROM data mover utility to merge with the clean firmware and write the merged firmware back to your drive using DOSFLASH again.aaronwt wrote:I juts ordered this drive from Amazon since they have a $25 rebate.
If I get lucky and it has firmware 1.02, am I able to use the clean 1.02 firmware and easily load it? Or do I need to go through the same convoluted process that you need to use for downgrading the firmware?
I just got a brand new ASUS BW-16D1HT drive from Newegg and the manufacture date is February 2018 ... have not installed in my enclosure yet, but I am assuming that it definitely will have the 3.03 firmware and I will need to use Teddy's method and patch it with the 3.02 clean firmware. Now to find an old PC .. I live in a Mac household
