Help with Failure of 1 Disc, Blade Runner Final Cut
SolomonJ
Post by SolomonJ » Wed Apr 18, 2018 11:23 pm
Out of my 25 or so UHD discs, this is the only one that fails every time. Below is drive/disc info and errors I see. I understand others are able to do this one, and I'm wondering if it's because I'm on a Mac with the drive in an external NexStar DX enclosure. Any thoughts? I have also tried a friend's physical disc and it behaves the same, so I'm sure it's not actually a media error. I've gone through the FAQ's without much success and would appreciate any insight if others have seen this.
OS device name: /dev/rdisk2
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.01
Serial number: SIK9DH2SF201
Firmware date: 2117-03-31 14:26:
Bus encryption flags: 1F
Highest AACS version: 63
Disc Information
Label: BLADE_RUNNER_THE_FINAL_CUT
Timestamp: 2017-07-17 19:27:03
Data capacity: 55.72 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
MakeMKV v1.12.0 darwin(x64-release) started
Optical drive "BD-RE PIONEER BD-RW BDR-XS06 1.10d" opened in OS access mode.
Optical drive "BD-RE ASUS BW-16D1HT 3.01d" opened in OS access mode.
File 00100.mpls was added as title #0
Title #00000.mpls has length of 8 seconds which is less than minimum title length of 300 seconds and was therefore skipped
File 00101.mpls was added as title #1
Title #00015.mpls has length of 30 seconds which is less than minimum title length of 300 seconds and was therefore skipped
File 00007.mpls was added as title #2
Title #00008.mpls has length of 30 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00009.mpls has length of 50 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00005.mpls has length of 23 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00007.m2ts has length of 7 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00012.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00004.m2ts has length of 12 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00901.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00003.m2ts has length of 19 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00000.m2ts has length of 1 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00062.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00008.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00009.m2ts has length of 4 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00017.m2ts has length of 5 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00019.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00026.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00025.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00024.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00023.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00022.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00021.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00016.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00015.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00014.m2ts has length of 11 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00013.m2ts has length of 11 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00010.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00002.m2ts has length of 5 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00005.m2ts has length of 139 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00061.m2ts has length of 5 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00900.m2ts has length of 10 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00020.m2ts has length of 4 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00018.m2ts has length of 0 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00064.m2ts has length of 35 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00006.m2ts has length of 151 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #00999.m2ts has length of 4 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Saving 1 titles into directory /Users/SolomonJ/Desktop
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00063.m2ts' at offset '29604900864'
Error 'Posix error - Device not configured' occurred while reading '/dev/rdisk2' at offset '29604900864'
Failed to save title 0 to file /Users/SolomonJ/Desktop/Blade_Runner_The_Final_Cut_t00.mkv
Encountered 21 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Encountered 147 errors of type 'OS X IPC Error' - see http://www.makemkv.com/errors/ipc/
0 titles saved, 1 failed
Krawk
Re: Help with Failure of 1 Disc, Blade Runner Final Cut
Post by Krawk » Mon Apr 30, 2018 12:08 am
What is your question?
You have a disc read error. There is a link at the bottom of the status screen.
Does not matter if the disc is brand new out of the package. Could be the disc itself, something on the disc from the factory even if the disc looks clean, or the drive having a mismatch with the disc.
android604
Post by android604 » Mon Apr 30, 2018 11:39 pm
I have the same problem with this Disc... always fails. All other UHD discs have been ok.
I'm using an ASUS bluray burner/reader.
Post by Woodstock » Mon Apr 30, 2018 11:55 pm
Did you check out the links?
While I doubt your IPC problems are power-related (the Asus drive is not USB-powered), there is still the problem that the drive encounters a read error, and stops talking to the Mac for a while.
If multiple attempts fail at the same offset, there is a very good chance that the problem is on the disk itself. If cleaning with a damp, soft cloth doesn't fix it, you should return it for replacement. It is very possible to have residue on the disk that you cannot see, but is like a brick wall between the blue laser and the disk.
