Able to rip UHD with KEYDB.cfg but not with keys_hashed.txt
hatesjetpacks
#1 Post by hatesjetpacks » Fri Apr 27, 2018 8:07 pm
I'm at a loss here, so hopefully this isnt an obvious problem. I have at least 2 UHD discs that I am able to rip when I have the doom9 KEYDB.cfg in the makemkv data directory. When I remove the KEYDB.cfg file, to make sure I'm using the keys_hashed.txt file (which is also in the makemkv data directory), I am unable to decrypt the same discs the I was able to with the KEYDB file present.
I would just send the dumps to the specified address for addition but I also read in the hashed keys thread that all doom9 keys are supposed to be included in the keys_hashed.txt file. This leads me to believe my setup is not working correctly for some reason.
I am using Makemkv 1.12.1. I am using the latest keys_hashed.txt (updated 27/4/18).
For one of the discs, here is output with KEYDB.cfg and keys_hashed.txt present in the makemkv data directory:
File 00020.mpls was added as title #0
Title #00612.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00801.mpls was added as title #1
Title #00194.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00613.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00607.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00182.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00605.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00606.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00610.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00611.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00608.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00609.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00604.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00195.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00251.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #2
Title #00250.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.m2ts has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00058.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00055.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00044.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00155.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00091.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00115.m2ts was added as title #3
Title #00109.m2ts has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00103.m2ts was added as title #4
Title #00102.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00099.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00096.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00093.m2ts has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00043.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00059.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00056.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00074.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00088.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00087.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00057.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00114.m2ts was added as title #5
Title #00113.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00112.m2ts was added as title #6
File 00111.m2ts was added as title #7
Title #00110.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00107.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00098.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00097.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00095.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00094.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00048.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00092.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00047.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00089.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00046.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00045.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00039.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00038.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00049.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00119.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00118.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00100.m2ts was added as title #8
Now, here is output with only keys_hashed.txt present in the makemkv data directory:
Saved AACS dump file as C:/UHD/MKB20_v60_The_Martian_-_Extended_Edition_9841.tgz
DEBUG: Code 0 at b4(+|7"2Y,<q/(je:121264257
DEBUG: Code 0 at b4(+|7"2Y,<q/(je:121265890
Thank you for your help.
Re: Able to rip UHD with KEYDB.cfg but not with keys_hashed.
#2 Post by mike admin » Fri Apr 27, 2018 9:40 pm
hatesjetpacks wrote: Saved AACS dump file as C:/UHD/MKB20_v60_The_Martian_-_Extended_Edition_9841.tgz
Must work, key is there. Is it just one disc? Are you sure the keys_hashed.txt is in the right place?
hatesjetpacks
#3 Post by hatesjetpacks » Fri Apr 27, 2018 9:55 pm
I have 5 discs and it doesnt work with any of them, including the 2 that I know will rip with KEYDB.cfg.
MakeMKV Data dir config:
File in the Dara dir:
Contents of file:
As I said I am at a loss. I am about ready to pull the drive out and try it in another pc. I moved the data dir to C:\UHD mostly because I was getting desperate and wanted to eliminate the possibility that spaces in the path were somehow causing a problem.
#4 Post by mike admin » Fri Apr 27, 2018 11:09 pm
hatesjetpacks wrote:I have 5 discs and it doesnt work with any of them, including the 2 that I know will rip with KEYDB.cfg.
Please try previous version 1.12.0 from http://www.makemkv.com/download/old . It is recommended to install alongside to different location.
hatesjetpacks
#5 Post by hatesjetpacks » Fri Apr 27, 2018 11:21 pm
That worked. I installed the old version along side the existing and now I can decrypt all five discs.
Thanks.
#6 Post by mike admin » Sat Apr 28, 2018 5:32 am
hatesjetpacks wrote:That worked. I installed the old version along side the existing and now I can decrypt all five discs.
Sigh. Fixed in 1.12.2 - please update.
hatesjetpacks
#7 Post by hatesjetpacks » Sun Apr 29, 2018 4:02 am
Uninstalled the two previous versions and installed 1.12.2 and able to decrypt without issue.
Thanks!!
