Ripping selected chapters
Seilenos
#1 Post by Seilenos » Sat Apr 14, 2018 8:48 pm
Hello.
First time received a DVD with music videos marked as 1 title with some chapters - 1 chapter - 1 different video.
Need to rip a cople of them. Is it possible in this software?
"toggle item" menu is unavalible.
Re: Ripping selected chapters
#2 Post by Woodstock » Sat Apr 14, 2018 10:07 pm
If the layout of the disk is one file with multiple chapters, then no, MakeMKV won't do it.
You can use MakeMKV to extract the whole file, and then use a tool like MKVmerge (part of MKVToolnix, google can find it) to separate the chapters into individual files.
Seilenos
#3 Post by Seilenos » Sun Apr 15, 2018 10:51 am
Thanks a lot. I use MKVToolnix a lot of years but didn't know about this function.
Mechanic
#4 Post by Mechanic » Fri Apr 27, 2018 3:15 pm
and if the disk layout consists of several files (with several partitions), can I do it?
thanks for the help. Mechanic
#5 Post by Woodstock » Fri Apr 27, 2018 4:59 pm
Theoretically, using the manual DVD open feature, you could define "titles" that consist of parts of other files, but I cannot offer any insight on how to do that.
(for me, it's simpler to rip the whole file, then break it up afterward with mkvtoolnix or handbrake)
