Anyone have issues reading Westworld 4K episodes 5 & 7...
Chuck_IV
#1 Post by Chuck_IV » Thu Apr 26, 2018 2:48 am
I don't know whether it's just a bad disk or if it's something else(I read all 3 episodes off the first disk just fine and 2 of the 4 off this disk), but when reading episode 5 I always get the following at the same spot(2632gb into the read)...
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00039.m2ts' at offset '3295997952'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '3295997952'
I'm not sure if I got a bum disk or not. The disk is spotless with no visible scratches at all(looks pristine), however, I even just tried coping the 00039.mts file and it hung on the copy too so I suspect a bad disk. I am using a US version purchased form Amazon. I am going to exchange it, but I figured I'd check before doing an exchange(since Amazon is backordered).
Re: Anyone have issues reading Westworld 4K episodes 5 & 7..
#2 Post by Woodstock » Thu Apr 26, 2018 1:26 pm
If the offset is the same between multiple reads, it is likely that is where a defect in the disk (could just be a fingerprint) exists.
Chuck_IV
#3 Post by Chuck_IV » Mon Apr 30, 2018 12:55 am
Yea, same spot every time. Guess I'll just send them back and wait on the replacements from Amazon(still on backorder).
lujan
#4 Post by lujan » Sat May 05, 2018 1:32 pm
Did anyone successfully rip "Westworld" UHD discs? I'm not sure which file should be ripped since there are twice as many files (>20GB) on discs as episodes? Maybe one is HDR10 and the other DV? Also, Infuse is choosing the old Westworld show when getting images and not the new one from 2016.
Chuck_IV
#5 Post by Chuck_IV » Wed May 09, 2018 3:44 am
After getting a replacement copy from Amazon, I've been able to rip them just fine now. The first copy I got had bad disks two and three. The second copy seems to be good though.
Lujan. On my USA copy from Amazon, while I do see two version of each episode, only one of them shows as having chapters, so those are the ones I ripped. They trigger HDR on my Samsung KS8000.
Maybe I'll rip one of the other ones to see what I end up with.
