Can't decrypt "Harry Potter and the Prisoner of Azkaban"?
nemesys
#1 Post by nemesys » Wed Apr 25, 2018 4:54 pm
I tried few times. I have the full movie collection. The first 2 movies were decrypted just fine. Now, MakeMKV won't decrypt the 3rd one, Harry Potter and the Prisoner of Azkaban.
Anyone else?
Here is the relevant log:
MakeMKV v1.12.0 darwin(x64-release) started
Optical drive "BD-RE TSSTcorp BDDVDW SE-506AB TS01d" opened in OS access mode.
Backing up disc into folder "/Volumes/Thunderbolt 6TB/Movies/HARRY_POTTER_AND_THE_PRISONER_OF_AZKABAN_3"
Error 'Scsi error - CONDITION MET' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:3cf1e1d2c4d776aa:TSSTcorp BDDVDW SE-506AB TS01'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command A30..0020..03F to device 'IoKit:IOBDServices:3cf1e1d2c4d776aa:TSSTcorp BDDVDW SE-506AB TS01'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command A40..0020..03F to device 'IoKit:IOBDServices:3cf1e1d2c4d776aa:TSSTcorp BDDVDW SE-506AB TS01'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command A30..0020..07F to device 'IoKit:IOBDServices:3cf1e1d2c4d776aa:TSSTcorp BDDVDW SE-506AB TS01'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command A40..0020..07F to device 'IoKit:IOBDServices:3cf1e1d2c4d776aa:TSSTcorp BDDVDW SE-506AB TS01'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command A30..0020..0BF to device 'IoKit:IOBDServices:3cf1e1d2c4d776aa:TSSTcorp BDDVDW SE-506AB TS01'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command A40..0020..0BF to device 'IoKit:IOBDServices:3cf1e1d2c4d776aa:TSSTcorp BDDVDW SE-506AB TS01'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command A30..0020..0FF to device 'IoKit:IOBDServices:3cf1e1d2c4d776aa:TSSTcorp BDDVDW SE-506AB TS01'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command A40..0020..0FF to device 'IoKit:IOBDServices:3cf1e1d2c4d776aa:TSSTcorp BDDVDW SE-506AB TS01'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command A40..002000800 to device 'IoKit:IOBDServices:3cf1e1d2c4d776aa:TSSTcorp BDDVDW SE-506AB TS01'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command A40..0020..07F to device 'IoKit:<unknown>'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command A30..0020..0BF to device 'IoKit:<unknown>'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command A40..0020..0BF to device 'IoKit:<unknown>'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command A30..0020..0FF to device 'IoKit:<unknown>'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command A40..0020..0FF to device 'IoKit:<unknown>'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command A40..002000800 to device 'IoKit:<unknown>'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command A30..0020..03F to device 'IoKit:<unknown>'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command A40..0020..03F to device 'IoKit:<unknown>'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command A30..0020..07F to device 'IoKit:<unknown>'
Error 'OS error - (ipc/send) invalid destination port' occurred while issuing SCSI command 280..001 to device 'IoKit:<unknown>'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/AACS/MKB_RO.inf' at offset '12888'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/AACS/MKB_RO.inf' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/AACS/Unit_Key_RO.inf' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/AACS/MKB_RW.inf' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/AACS/Content000.cer' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/AACS/Content001.cer' at offset '0'
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/AACS/ContentRevocation.lst' at offset '0'
Saved AACS dump file as /Users/laurent/.MakeMKV/MKB_v4_HARRYPOTTER3_33F4.tgz
Backup failed
Backup failed
Re: Can't decrypt "Harry Potter and the Prisoner of Azkaban"
#2 Post by Woodstock » Wed Apr 25, 2018 7:06 pm
The error messages you're getting point to a disk issue - the drive is trying to read the disk, but goes off-line, as far as the computer is concerned.
The movie disk itself is generally readable, as far as encryption is concerned, because I have that same set and have ripped all of the movies in it.
Is the drive plugged directly into your Mac, or into a hub?
nemesys
#3 Post by nemesys » Wed Apr 25, 2018 7:38 pm
Woodstock wrote:The error messages you're getting point to a disk issue - the drive is trying to read the disk, but goes off-line, as far as the computer is concerned.
It was plugged in a hub that never gave me any troubles but after reading the error messages from MakeMKV, I plugged it directly in my Mac and that seems to have done the trick. I was able to decrypt the 5th movie of the series without any problem. Are hubs going bad all of a sudden? There are no moving parts in them. I tried a different port on my hub with the same result. That's when I decided to plug it directly to the Mac.
#4 Post by Woodstock » Wed Apr 25, 2018 8:41 pm
No, the issue is usually the drive starts spinning faster than the hub can provide power for. USB-powered drives really push the maximum power limits on a USB port, and any hub that does NOT have its own power supply is splitting 1 "USB power unit" between itself and everything plugged into it.
Some drives come with a two-head cable to get more power, but both plugs should go to "fully powered" USB ports; plugging them both into a non-powered hub just makes the situation worse.
nemesys
#5 Post by nemesys » Wed Apr 25, 2018 8:51 pm
Woodstock wrote:No, the issue is usually the drive starts spinning faster than the hub can provide power for. USB-powered drives really push the maximum power limits on a USB port, and any hub that does NOT have its own power supply is splitting 1 "USB power unit" between itself and everything plugged into it.
Interesting. Because my hub has its own power supply.
#6 Post by Woodstock » Thu Apr 26, 2018 12:07 am
How many things plugged in?
I have a 7-port hub that came with a power supply rated for 5v 2a... which is "4 USB power units". That works fine for 6 Seagate 2TB "backup plus" portable drives, but I unplug those and use the dual-head cable for the LG USB BD writer.
nemesys
#7 Post by nemesys » Thu Apr 26, 2018 12:12 am
Woodstock wrote:How many things plugged in?
Hmmm... I have a Saitek X52 Pro, a USB mouse, an M-Audio Fastrack, a Strix headset and my Samsung Blu-ray drive. But I had this setup for several months now and had been able with the same devices to decrypt Blu-ray discs multiple times. I just don't understand why the drive is suddenly working intermittently...
#8 Post by Woodstock » Thu Apr 26, 2018 1:01 pm
Does the hub have a "power" light on it? Some do, most don't, but it lights up when the power supply is plugged in. If it isn't lit, the power is coming exclusively from the upstream USB port.
Also, a partially-powered drive can usually do just fine up to about 2-3x read speed. I've done testing here on a known-limited port, and my LG drive had no problem below 4x, but spat out lots of errors above that. I was testing to see if using a slow USB flash drive as the ripping target could be a work-around for keeping rip speeds low.
nemesys
#9 Post by nemesys » Sun Apr 29, 2018 9:17 pm
Woodstock wrote:Does the hub have a "power" light on it? Some do, most don't, but it lights up when the power supply is plugged in. If it isn't lit, the power is coming exclusively from the upstream USB port.
Yes, the hub has a "power-on" light. And it's on. I re-connected the drive to the hub, although a different port. I have been able to decrypt 4 Blu-rays and 1 DVD without any problem. Go figure...
Wayned
#10 Post by Wayned » Thu Jun 21, 2018 7:32 pm
I'm having similar problems with LBJ (a month ago) & The blind side. This used to work...<arrrgh>
I had heard/rumor that the keys/encryption had been changed but that didn't make any sense since that would render older players obsolete. Maybe I'll try another drive.
Wayne D.
This clown speaks for himself
nemesys
#11 Post by nemesys » Thu Jun 21, 2018 8:09 pm
Well, I finally resolved the issue by connecting my drive directly to my computer. Somehow, the drive was not getting enough power from the powered hub...
Wayned
#12 Post by Wayned » Fri Jun 22, 2018 1:48 pm
Using a USB power supply along with a double ended cable (2 standard USB2 plugs, 1 micro USB) for a BluRay drive, I could backup The Blind Side. LBJ still fails... here are the error messages:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..08B50B30557609B1E6B7B69C4C4E92211ED to device 'IoKit:IOBDServices:0fe8e3a4acff63e6:PIONEER BD-RW BDR-XD05 3.01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:0fe8e3a4acff63e6:PIONEER BD-RW BDR-XD05 3.01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BC65498BBBEF47827D2C4E3B970A7687BE to device 'IoKit:IOBDServices:0fe8e3a4acff63e6:PIONEER BD-RW BDR-XD05 3.01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D2453F0F995F791D05E801FA8F27A38500 to device 'IoKit:IOBDServices:0fe8e3a4acff63e6:PIONEER BD-RW BDR-XD05 3.01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..05C10B87684A72B2896C68DA810F7FC598A to device 'IoKit:IOBDServices:0fe8e3a4acff63e6:PIONEER BD-RW BDR-XD05 3.01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0EEE9848E99FB56F8AB0..08F4930A7931E to device 'IoKit:IOBDServices:0fe8e3a4acff63e6:PIONEER BD-RW BDR-XD05 3.01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..07DC4ECE78EB12C37248D9E6C4320645D47 to device 'IoKit:IOBDServices:0fe8e3a4acff63e6:PIONEER BD-RW BDR-XD05 3.01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..014388ABE03B3EC2E5D7A4247197D36AC90 to device 'IoKit:IOBDServices:0fe8e3a4acff63e6:PIONEER BD-RW BDR-XD05 3.01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0D8B64715E1C89C08CBB902360431E5076F to device 'IoKit:IOBDServices:0fe8e3a4acff63e6:PIONEER BD-RW BDR-XD05 3.01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..08AF9298812E5C1C41AEEB22540B407526A to device 'IoKit:IOBDServices:0fe8e3a4acff63e6:PIONEER BD-RW BDR-XD05 3.01'
Highest AACS version is v63 , MKB saved as /Users/wayned/Library/MakeMKV/MKB_v63_LBJ_2017.tgz
Backup failed
#13 Post by Woodstock » Fri Jun 22, 2018 4:37 pm
The SCSI errors you're getting aren't related to drive power issues. MakeMKV was not able to read the part of the disk that contains key information, which is usually because that part of the disk is dirty or damaged.
Cleaning is the first attack on this sort of issue. Soft, damp cloth.
Wayned
#14 Post by Wayned » Wed Jun 27, 2018 11:25 pm
Hmmm, I bought this one new from Walmart from there bargain bin, I just checked the back side and it looks to be in great shape, no smudges, scratches, etc. I'll see if I can play it on a BluRay player,
Wayned
#15 Post by Wayned » Thu Jun 28, 2018 9:06 pm
I tried LBJ on an older (5+ years) BluRay player, it took awhile (minutes) to load but it did play. I wonder if makeMKV is timing out? The two BluRay drives are about a year old.
