Hostiles correct playlist
JediSamReye
Hello all! I just installed run time environment to get this going. If anyone needs the red playlist it is Segment map: 511,501,506,513,508,512,507,503,510,515,502,514,505,504,509
chadjamesr
Re: Hostiles correct playlist
I find the segment map to be the same and the source file name to be 00208.mpls.
Thanks for the info, folks.
UsedKondomXL
How do you get MakeMKV to tell you that one is the Main Feature ? I installed the Java JRE and pointed at it in the preferences but still nothing.
There is no need to specify Java in the preferences. MakeMKV find the standard Java implementation. This option is only to specify a special Java implementation.
If MakeMKV needs Java you shoud see these messages in the log:
Found java version=1.8.0.171 path=C:\Program Files\Java\jre1.8.0_171\bin\java.exe
Found java version=1.8.0.171 path=C:\Program Files (x86)\Java\jre1.8.0_171\bin\java.exe
003344:0000 Using Java runtime from C:\Program Files\Java\jre1.8.0_171\bin\java.exe
To check if Java is overall accessible open a "DOS Window" and type "Java -version". You should now see the java version information.
Good Luck
