Bunch of early 2017 ASUS BW-16D1HTs at this location as well, what firmware version am I looking for? The sticker is rather cryptic.
Thank you,
Alex
UHD drives
st4evr
Re: UHD drives
MakeMKV will return the Firmware version ("Revision") once the drive has been installed. The Asus drives do NOT have the Firmware listed on the label like the LGs for the most part.alexcoluzzi32 wrote:Bunch of early 2017 ASUS BW-16D1HTs at this location as well, what firmware version am I looking for? The sticker is rather cryptic.
Thank you,
Alex
Example:
http://www.makemkv.com/forum2/viewtopic ... ion#p61811
Beware of some 3.02 versions that fix the loophole as also mentioned in that linked thread.
alexcoluzzi32
Re: UHD drives
Got it, thank you very much.st4evr wrote:MakeMKV will return the Firmware version ("Revision") once the drive has been install. The Asus drives do NOT have the Firmware listed on the label like the LGs for the most part.alexcoluzzi32 wrote:Bunch of early 2017 ASUS BW-16D1HTs at this location as well, what firmware version am I looking for? The sticker is rather cryptic.
Thank you,
Alex
Example:
alexcoluzzi32
Re: UHD drives
I'm getting some funky results with these LG drives I bought at Fry's. I'm thinking it's less about the drives and more about my config. I've got an 2017 HP Envy 750-624 with Windows 10 Pro and a 2010 Dell Studio XPS 7100 running Windows 7 Home Premium. Wondering which thread discusses basic and advanced makemkv configs people are using. I think I need to double check a bunch of stuff, like background resources that could be getting in the way of the program doing it's thing, pointing to the wrong jar file, sleep and power settings, hell I dunno, is it because I'm using the same reg key on two PCs? (never at the same time granted). I'm starting to get mad errors but they're the same across these 4 drives so me thinks either a pallet load of shit drives or user error....
smartieyoung
Re: UHD drives
I'm happy with my uhd friendly LG drive its been a really good drive,however im aware that it will eventually go bad as time goes on.Ive reviewed the list of friendly uhd drives on the first page, the prospect of possibly having to flash a drive with friendly firmware seems daunting to me,so im not really sure what a good backup drive would be? I have an acer Tc 605 aspire running latest version of windows 10 home.If it helps i like external drives they seem easier to work with.
st4evr
Re: UHD drives
You can do what these guys are doing:smartieyoung wrote:I'm happy with my uhd friendly LG drive its been a really good drive,however im aware that it will eventually go bad as time goes on.Ive reviewed the list of friendly uhd drives on the first page, the prospect of possibly having to flash a drive with friendly firmware seems daunting to me,so im not really sure what a good backup drive would be? I have an acer Tc 605 aspire running latest version of windows 10 home.If it helps i like external drives they seem easier to work with.
http://www.makemkv.com/forum2/viewtopic ... 16&t=17364
It is a thread about Mac, but for external drives the same applies for Windows.
We all have slim pickings. The friendly/supported list is small, so pick and pray.
steelerfan
Re: UHD drives
i'm on my 3rd drive trying to make this work with my MAC (to be fair i bought the other 2 without finding this thread)..
Today the LG WH16ns40 arrived & I am using the Vantec NST-536S3-BK NexStar DX USB 3.0 External Enclosure for SATA Blu-Ray/CD/DVD Drive and I'm having the same exact problem. It shipped with firmware version 1.03
I put the UHD disc (tried 5 different disk today), the drive spins.. and spits it back out.... I can successfully read a BlueRay no problem.
I never even get to the step with MakeMKV to click on the disc
This is so frustrating. I have a home built Server in my house that runs Server 2008R2 that I could pop the drive in & see if it's a MAC problem or what.. not even sure if MKV runs on Server 2008.
I feel like there has to be something small i am doing wrong.. i have successfully backed up 30+ bluerays so far but really want to get my UHD's on my NAS as i don't have a UHD player in every room of the house
fljoemon
Re: UHD drives
@steelerfan .. unfortunately it has been reported in couple of threads that firmware 1.03 on the LG drive do not work as LG fixed the ACCS loophole. You will need to crossflash it with ASUS clean 3.02 firmware following Teddy's guide https://www.makemkv.com/forum2/viewtopi ... 16&t=17058
Asus 3.02 clean firmware: https://www.makemkv.com/forum2/viewtopi ... =75#p59568
OR
Use the clean firmware for LG drives from here: http://www99.zippyshare.com/v/k7ZbMprP/file.html and use Teddy's procedure to dump/merge/write firmware to the drive.
OR
fljoemon
Re: UHD drives
WooHoo .. won the drive lottery thanks to Alex ... got a LG-WH16NS40 with SVC code: NS50. Definitely 4K UHD friendly .. don't know for sure the firmware inside until I plug it in my enclosure and run MakeMKV.alexcoluzzi32 wrote:I was thinking if you chose the Palo Alto location as "My Store" maybe they'd take it out of their stock but maybe that's naive thinking....fljoemon wrote:Thank You Alex for posting .. I did order the LG drive from Fry's with the coupon, so $54.99 and free shipping. I hope I get a drive with the friendly firmware since I do not know which warehouse this drive will be shipped from. Else I will need to find a old PC and flash it with the friendly firmware following Teddy's guide that has been posted. This forum is amazing and thanks to all members who respond and help us.
Definitely let me know how it works out!
Here's couple of pics ...
alexcoluzzi32
Re: UHD drives
Fine job sir! Please keep us, or me, posted about how that thing works. I'm heading over there now to buy a 4th LG and at least one ASUS before they stop allowing me to use the same promo code over and over again.fljoemon wrote:WooHoo .. won the drive lottery thanks to Alex ... got a LG-WH16NS40 with SVC code: NS50. Definitely 4K UHD friendly .. don't know for sure the firmware inside until I plug it in my enclosure and run MakeMKV.alexcoluzzi32 wrote:I was thinking if you chose the Palo Alto location as "My Store" maybe they'd take it out of their stock but maybe that's naive thinking....fljoemon wrote:Thank You Alex for posting .. I did order the LG drive from Fry's with the coupon, so $54.99 and free shipping. I hope I get a drive with the friendly firmware since I do not know which warehouse this drive will be shipped from. Else I will need to find a old PC and flash it with the friendly firmware following Teddy's guide that has been posted. This forum is amazing and thanks to all members who respond and help us.
I'd sure love to compare notes with someone about Windows PC configurations. To be more specific, how much crap can I uninstall / turn off, to free up resources, so makemkv can do it's work with these drives, using Windows 10 Pro and/or Windows 7 Home Premium. Something is the source of my errors but at this point not sure if it's hardware, software or user (most likely user
alexcoluzzi32
Re: UHD drives
This is starting to really suck. And I realize this is not the right place to post, so I apologize.
DEBUG: Code 0 at k`Gfy'w(Cq4$)}}QB'PA:213131341
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 27377664, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 27377664-27383808, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 27383808, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 27383808-27389952, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 27389952, attempting to work around
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 27672576, attempting to work around
DEBUG: Code 2 at "Fcu$U`[_;>QFzKJ:213132928
DEBUG: Code 0 at :TZBv"<vmt/\_M%9YF-S:213129593
DEBUG: Code 0 at 3XlDYsJl#uRZ9E-f\B=7:213131387
DEBUG: Code 0 at js~o!'PoT+fMv%n6[f3G8:29399197
DEBUG: Code 1 at "Fcu$U`[_;>QFzKJ:121263498
DEBUG: Code 0 at "Fcu$U`[_;>QFzKJ:121264832
Failed to save title 1 to file D://MARVEL'S_THOR_RAGNAROK_t01.mkv
Encountered 3 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 2 failed
Snippet of the log to the end. I don't get it. I did Deepwater Horizon, Goodfellas, Push, and part of Labyrinth before this went to hell. Tried Revanant next same shit. Reinstalled Windows 10 Pro, removed all bloatware, uninstalled every application that was not needed. I've got Java, VLC and MakeMKV on this machine and that's pretty much it. Hashed key file in the correct directory. I assume I've specified the correct Java Executable and DTS Decoder in the preferences. Profile I'm using is FLAC. Everything else is default since I'm not sure what most of them mean. Is it because I'm sending the output to another internal SATA drive as opposed to the drive that makemkv is running on?
Logs:
https://drive.google.com/open?id=18fPN_ ... 4yVpO07DzP
Logs:
alexcoluzzi32
Re: UHD drives
Bought the last two ASUS BW-16D1HTs at my local Fry's, one comes with a $25 rebate, score. Bought 4 more of the LG WH16NS40s bringing my total now to 7, all using the same promo code because those idiots are unable to read apparently.
Of the two ASUS one has 3.0.0 and the other 3.0.1 and seem to be working much better than the LG so I'm not sure what the fuck is up. It seems these drives, the ASUS and LG, either work from the get go, or start making sounds like they're straining to read the disc over and over and over again then fill the log with all sorts of errors and eventually the hash check error.
If other users have luck with these Fry's LG drives I found then cool it's my bad, if not I'm returning every single fucking one. It's bad enough these assholes are stealing the digital codes out of UHD Blu Ray packages, but to be selling a ton of bad drives yeah that's not going to fly. I guess that's what happens when you're paid $4 an hour to work in a building on top of a SuperFund site....
alexcoluzzi32
Re: UHD drives
Finally have one stable setup with the quad core i7 machine and the ASUS BW-16D1HT with 3.00 firmware on it. Fuck me I've been dicking with these setups for two weeks now.
Hey what do you guys do about discs that have multiple titles of the same size? I don't get it why the first couple Harry Potters had two identical titles, at least I didn't see any difference. I ripped them both because I'm not doing this again, and hard drives are inexpensive, but heck that's a massive directory.
fljoemon
Re: UHD drives
Alex .. those identical streams are titles with a different language .. I read it in this thread https://www.makemkv.com/forum2/viewtopi ... 12&t=16993
alexcoluzzi32
Re: UHD drives
I believe you! Although I just spot checked each one didn't hear or see a difference although one had extra soundtrack options, definitely not in Japanese or any other language
