Volume Key Unknown - BBC Earth "Wild Africa / tiny Giants"
alexcoluzzi32
What is the data you guys need here, if anything?
Re: Volume Key Unknown - BBC Earth "Wild Africa / tiny Giant
Are you trying to open an original BD, or an ISO of a BD?
What other errors did you receive when opening the disk?
alexcoluzzi32
It's an original and I'll try again and post screen caps, or something. Thank you!Woodstock wrote:Are you trying to open an original BD, or an ISO of a BD?
Debug logging is far more valuable than screenshots.
alexcoluzzi32
Your wish is my command sir.Woodstock wrote:Debug logging is far more valuable than screenshots.
https://drive.google.com/file/d/1P6hYJY ... sp=sharing
Very strange - AACS v61 isn't the "latest and greatest", so MakeMKV 1.12.x should be able to decode it, assuming it can read the root directory properly.MakeMKV v1.12.0 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\XXXXX/MakeMKV_log.txt
DEBUG: Code 0 at ap|/'{OFxXWgeC:121262164
DEBUG: Code 0 at mV4(%n/4s|39{CnS:213136033
Saved AACS dump file as C:\Users\XXXXX/.MakeMKV/MKB20_v61_BBC_Earth_EDE8.tgz
DEBUG: Code 0 at mV4(%n/4s|39{CnS:121264257
DEBUG: Code 0 at mV4(%n/4s|39{CnS:121265890
As a test to see if it's a problem specifically with 1.12, could you install one of the 1.10 versions from /download/old/ ? v1.10.6 and later should also be able to handle this disk.
pitsie
That's a UHD/AACS2 disc I think, hence the "MKB20".Woodstock wrote: Saved AACS dump file as C:\Users\XXXXX/.MakeMKV/MKB20_v61_BBC_Earth_EDE8.tgz
PilotC150
What is the latest and greatest version? I'm trying to rip The Greatest Showman bluray and I'm getting the same error, except it's AACS v63. I don't want to hijack this thread, but it's a coincidence that this thread was started yesterday and I'm having the problem today. I'm curious if the probably is related. This is a "truncated" error log. The only part I cut out was more lines of the illegal request lines.Woodstock wrote: Very strange - AACS v61 isn't the "latest and greatest", so MakeMKV 1.12.x should be able to decode it, assuming it can read the root directory properly.
As a test to see if it's a problem specifically with 1.12, could you install one of the 1.10 versions from http://makemkv.com/download/old/ ? v1.10.6 and later should also be able to handle this disk.
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0401ECF4447905FC86405BF90D14CB47453 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Highest AACS version is v63 , MKB saved as C:\Users\Chris/.MakeMKV/MKB_v63_THE_GREATEST_SHOWMAN.tgz
V1.12.0 of MakeMKV can handle AACS v64, which has been out for a few months.
I'm sure we'll get reports when v65 hits stores.
PilotC150
Yup, that’s my bad. I thought I was on latest. Once I updated all was good!Woodstock wrote:V1.12.0 of MakeMKV can handle AACS v64, which has been out for a few months.
Thanks for the response.
