Correct .mpls file for The commuter 2017
starktony
#1 Post by starktony » Thu Apr 12, 2018 9:21 pm
Please help me in determining the correct .mpls file in the commuter. This lionsgate error started coming in last 4 days only otherwise everything was running fine .Even my old BD's which ran fine till this date started giving me this error. If someone can help me with this problem it will be of great help
I checked 0001 but that was error. Would really appreciate your help.
Kind Regards
Re: Correct .mpls file for The commuter 2017
#2 Post by Woodstock » Thu Apr 12, 2018 10:16 pm
What is the "lionsgate error"?
hvnphoto
#3 Post by hvnphoto » Fri Apr 13, 2018 3:28 pm
U.S. Retail
Title information
Source file name: 00484.mpls
Duration: 1:44:55
Chapters count: 16
Segment count: 15
Segment map: 512,502,504,508,515,514,506,511,501,503,507,513,509,510,505
File name: The_Commuter_t184.mkv
bill2468
#4 Post by bill2468 » Tue Apr 17, 2018 1:58 pm
Is there a correct mpls for the Redbox version of The Commuter?
ciberoker
#5 Post by ciberoker » Tue Apr 17, 2018 8:09 pm
Hi Everyone,
I'm pretty much new to the scene, I wanted to contribute.
This one worked for me. Can someone else confirm?
Title information
Source file name: 00448.mpls
Duration: 1:44:55
Chapters count: 16
Segment count: 15
Segment map: 514,502,511,515,512,506,503,513,508,501,505,507,509,510,504
File name: The_Commuter_t173.mkv
tehknics
#6 Post by tehknics » Tue Apr 17, 2018 8:59 pm
00484.mpls was not an option on Redbox. Trying 00448.mpls.
fozbot
#7 Post by fozbot » Tue Apr 17, 2018 9:32 pm
US Redbox
Comment: FPL_MainFeature
Source file name: 00629.mpls
Duration: 1:44:55
Chapters count: 16
Segment count: 15
Segment map: 514,502,511,515,512,503,510,505,508,509,501,513,506,507,504
File name: The_Commuter_t04.mkv
Note: I had to install Java for the disc to recognize the "FPL_MainFeature" tag.
fozbot
#8 Post by fozbot » Tue Apr 17, 2018 11:26 pm
Watched and confirmed good
bretb
#9 Post by bretb » Wed Apr 18, 2018 12:24 am
fozbot wrote:US Redbox
Duration: 1:44:55
Chapters count: 16
Segment count: 15
I'm impressed with how well the Java feature works on MakeMKV to identify the correct stream automatically.
Has it ever identified the wrong stream?
I was a MakeMKV owner for months before I realized that this feature works, only if you install Java on the system. I wish that had been more clear, sooner. Or, perhaps it is and I just didn't read enough to see it.
Fortissimo
#10 Post by Fortissimo » Thu Apr 19, 2018 5:27 pm
bretb wrote:I was a MakeMKV owner for months before I realized that this feature works, only if you install Java on the system. I wish that had been more clear, sooner. Or, perhaps it is and I just didn't read enough to see it.
I was a user for years before realizing this was possible. Another thread that may be of interest:
https://www.makemkv.com/forum2/viewtopi ... 195#p62195
thejester
#11 Post by thejester » Fri Apr 27, 2018 11:23 pm
bretb wrote:
fozbot wrote: I was a MakeMKV owner for months before I realized that this feature works, only if you install Java on the system. I wish that had been more clear, sooner. Or, perhaps it is and I just didn't read enough to see it.
Apparently take a little time to "sync" with current java version - in this case #171?
Forgot & found the place to specify java install directory.
mr.ripper
#12 Post by mr.ripper » Tue May 22, 2018 9:00 pm
Anyone knows the correct playlist for the nordic version of this disc? I have Java installed, but still gets about 400 titles and no "FPL_MainFeature". About half of them with 20 segments, and half of them with 21 segments. Duration either 1:44:26 or 1:29:37. Randomly selected title looks like this:
Title information
Source file name: 00138.mpls
Duration: 1:44:26
Chapters count: 8
Segment count: 21
Segment map: 509,506,5,503,518,504,514,517,512,510,519,515,520,501,508,507,500,513,502,505,511
File name: title49.mkv
Thanx.
Edit: mixed up discs at first.
mr.ripper
#13 Post by mr.ripper » Sun May 27, 2018 8:22 pm
To answer my own question, this seems to be the correct one for the Nordic version of the disc:
Title information
Source file name: 00494.mpls
Duration: 1:44:26
Chapters count: 8
Segment count: 21
Segment map: 509,5,506,503,518,504,512,517,510,514,519,507,520,501,508,515,500,513,505,502,511
