Newbliss
#227
Post
by Newbliss » Thu Apr 05, 2018 9:48 pm
I thought the 3.02 FW worked though? I'm having the same issue of January 2018 manufacture date 3.02 FW but no discs or reading. Might just be bad luck with discs having different keys. Anyone know if there is truly no hope for my drive?
XDUDE3D
#228
Post
by XDUDE3D » Thu Apr 05, 2018 9:55 pm
Haha, Thanks! I already stumbeled onto that, got my drive reflashed clean to 3.02 and currently have passengers UHD going just fine! Thanks again!
And anyone else with my same issue, the above linked topic IS THE ANSWER.
st4evr
#229
Post
by st4evr » Thu Apr 05, 2018 11:25 pm
Newbliss wrote:I thought the 3.02 FW worked though? I'm having the same issue of January 2018 manufacture date 3.02 FW but no discs or reading. Might just be bad luck with discs having different keys. Anyone know if there is truly no hope for my drive?
See this thread.
http://www.makemkv.com/forum2/viewtopic ... 12&t=17313
Clarifies a bit on some of the issues discovered/discussed so far with "newer" 3.02 firmware now shipped with those drives.
tapidlittle
#230
Post
by tapidlittle » Fri Apr 06, 2018 4:32 am
I have a LG BU40N which seems to be an official reader.
Any idea if it will ever be supported?
DEUHD says it's supported but I tried it and it won't work.
Also someone here claim he his able to revert an official reader to a friendly reader, what about that?
thanks.
st4evr
#231
Post
by st4evr » Fri Apr 06, 2018 5:11 am
That is entirely up to Mike.
Because DeUHD currently supports some official UHD drives does not mean MakeMKV (or other similar apps for that matter) will also support them. Different apps, different development, different developers, and their aproach may vary even though they are all aiming towards the same goal.
Mike has said that at some point one or more official UHD drives may be supported by MakeMKV as he is working on something. When will that be officially released? Only he knows. All we can do is patiently wait until the release of this version is announced and available for download/purchase.
As for the conversion you speak of. Some have been successful and others not so much. You’ll have to decide whether you feel comfortable to give that method a try or not.
st4evr on Fri Apr 06, 2018 3:09 pm, edited 1 time in total.
tapidlittle
#232
Post
by tapidlittle » Fri Apr 06, 2018 11:57 am
st4evr wrote:That is entirely up to Mike.
Mike has said that at some point one of more official UHD drives may be supported by MakeMKV as he is working on something. When will that be officially realeased? Only he knows. All we can do is patiently wait until the release of this version is announced and available for download/purchase.
As for the conversion you speak of. Some have been successful and others not so much. You’ll have to decide whether you feel comfortable to give it a try or not.
thanks.
mtucker
#233
Post
by mtucker » Sat Apr 07, 2018 1:42 pm
XDUDE3D wrote:Just received a ASUS BW-16D1HT but manufactured January 2018 (3.02).....
Anyway I can salvage this? Or is another buy'n'hope it?....
You sure can. Use the clean 3.02 FW given just a few posts before yours. My January 2018 drive would not read a UHD disk when I got it, but works great after I dumped my FW, combined with the clean, and reflashed. My computer skills are mediocre, but I got through the FW process following this thread
https://www.makemkv.com/forum2/viewtopi ... 16&t=17058
lujan
#234
Post
by lujan » Sun Apr 08, 2018 8:58 pm
Will this external drive work with UHD discs and MakeMKV?
ASUS USB 2.0 / USB 3.0 External 16X Blu-Ray Re-writer MacOS Compatible Model BW-16D1X-U LITE/BLK /G /AS
#235
Post
by Woodstock » Mon Apr 09, 2018 12:07 am
No, the BW-16D1X-U is not a BDXL-capable drive, despite its model number, and description in the ad you originally linked to.
I bought one, and then gave it away to a Mac user, who then put it on his Windows box because the Mac didn't like it very much.
lujan
#236
Post
by lujan » Mon Apr 09, 2018 1:57 am
Woodstock wrote:No, the BW-16D1X-U is not a BDXL-capable drive, despite its model number, and description in the ad you originally linked to.
Are there any external drives that work?
tapidlittle
#237
Post
by tapidlittle » Mon Apr 09, 2018 11:43 am
tapidlittle wrote:I have a LG BU40N which seems to be an official reader.
thanks.
I have contacted DeUHD for my drive and they say I need firmware A101, now I have A102.
Anyone know where I can get this firmware?
thanks.
B17NNS
#238
Post
by B17NNS » Mon Apr 09, 2018 7:19 pm
Mine has just arrived. Manufactured September 2017. Haven't got an enclosure yet but will this work out of the box?
st4evr
#239
Post
by st4evr » Mon Apr 09, 2018 9:33 pm
thanks.
They are advising you downgrade. READ this thread carefully and follow the instructions if you wish to downgrade:
http://www.makemkv.com/forum2/viewtopic ... 16&t=17058
And again as it has been CLEARLY stated before, if you wish to have support for this drive at this time, you will have to buy DeUHD (if you have not already).
alexcoluzzi32
#240
Post
by alexcoluzzi32 » Fri Apr 13, 2018 7:22 am
WH16NS40
SVC CODE: NS50
ROM version 1.03
Built January 2018
I'm hosed yes?
