Version 12 Cannot Open UHD Blu-Rays, but Version 10 Can
PeterKin
Post by PeterKin »
I'm a new user so forgive me if this seems too basic an issue to raise here. I tried the 30-day trial of MakeMKV version 1.10.10 and successfully backed up one of my 4K UHD Blu-ray discs to a NAS. So I purchased a licence and then noticed a message saying an update to version 1.12 was available. After installing the update I found Make MKV could no longer Open any UHD discs, including the one I'd previously been able to backup. So I uninstalled version 1.12 and reinstalled vesion 1.10.10 and it's working again. So, unless I've missed something, it looks like version 1.12 not longer works with UHD Blu-Rays. :?:
st4evr
Re: Version 12 Cannot Open UHD Blu-Rays, but Version 10 Can
Post by st4evr »
Version 1.12 has been out for literally several months.
Many users--including myself--have successfully decrypted many UHD discs using this version since its release.
Are you following the instruction posted by Mike in this sticky for the updated Hashed keys?
http://www.makemkv.com/forum2/viewtopic ... 12&t=16959
Are you making sure that this hash key file is in the correct place when updating to 1.12?
PeterKin
Post by PeterKin »
Hi st4evr,
I'm putting the hasked keys file in the MakeMKV directory. That's exactly what I did with version 1.10.10, and it worked prefectly. But since updating to version 1.12 it won't work. MakeMKV recognizes, displays the name, but fails to open any disc and creates a .dmp file each time I try. I have tried re-downloading a fresh copy of version 1.12 (just in case the first was corrupted), but that doesn't work either.
I followed your link to Mike's sticky and read that you're supposed to put the hashed keys file into the MakeMKV "data directory" - but there is no data directory within the MakeMKV directory, so does this mean there's a directory I haven't found yet or am I doing the right thing and it's just not working?
Thanks,
PeterKin
Post by d00zah »
The data directory should NOT be stored under the main program directory & is explicitly set apart so it is not deleted with each program update. Check 'Preferences' > 'General' tab where the 'MakeMKV data directory' path is defined.
PeterKin
Post by PeterKin »
d00zah, that's brilliant! Thanks. Moved the hashed keys file and it now works. Maybe I missed something in the instructions somewhere, but it's all sorted now.
PerterKin
Ham Bone
Post by Ham Bone »
So many posts that refer to the term "hashed key file" and where to put it. So, I went to the location for this file and downloaded that file. It is named "keys_hashed.txt". So, is it correct to simply place this file, as is and without naming it, into the MakeMKV User data directory? Thanks.
st4evr
Post by st4evr »
Yes. As Mike states in that same post where you download the file from:
"just download the relevant text file and put it into MakeMKV data directory."
There is no mention at all of renaming the file. Do as Mike instructs and you will be ok.
Ham Bone
Post by Ham Bone »
st4evr wrote:Yes. As Mike states in that same post where you download the file from:
Excellent. Thank you.
danny74
Post by danny74 »
good morning
I put the keys in the data directory (the location where Makemkv is installed). Is that correct? I have problems that cancel the UHD's after half. Versus Shape of Waters. Key is deposited for the film. Why does this not work. Have a LG UHD friendly drive. Where in which location does this really need to go? Please help
i have the newest Version of makemkv!
many thanks
st4evr
Post by st4evr »
danny74 wrote: Tue Oct 16, 2018 6:30 am good morning
many thanks
1. As d00zah literaty instructs a couple of posts above:
d00zah wrote: Thu Mar 29, 2018 3:59 pm The data directory should NOT be stored under the main program directory & is explicitly set apart so it is not deleted with each program update. Check 'Preferences' > 'General' tab where the 'MakeMKV data directory' path is defined.
READ and follow his instructions and you’ll be fine.
2. READ THIS:
viewtopic.php?f=1&t=17872
Try version 1.12.2.
danny74
Post by danny74 »
i tried everything as described, but it does not work. Version 1.12.2
st4evr
Post by st4evr »
Post the errors you are getting in the error log (if any).
danny74
Post by danny74 »
Debug log started at Wed Oct 17 15:53:22 2018 , written by MakeMKV v1.12.2 win(x64-release)
001005:0000 MakeMKV v1.12.2 win(x64-release) gestartet
003007:0000 Direkter Zugriffsmodus wird verwendet
DEBUG: Code 2365587456 at #JEH3khy]yJ.Vdvo:121271065
DEBUG: Code 2147483648 at #JEH3khy]yJ.Vdvo:29396483
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=MLz/rsbBD+CQFvib6CTzo41P1fEwa4pdT/7pF50HT9h/4H4uXoYax6I6FN34zYFL2FSBClXErhZoJqPNgbXeD+Ibn3b5PRIP0GuBbgBxgPi6bEBM2Xfgwr/uFkE/7kj3SeIJ0Z/ZDo76/Tr8qBYXLwmPcgXmGl0LAw==
DCE=sLZpuakmITdlPzLP1Bqyf9vNKc/DHf1LYDXJwzAB8FODoOw84Jb1PijlgTUolabN+MJ+XB34N5s/Rzrc0xLGnGNweUr/+eGtsKicoyUWBb2sZ9TcL6eRJ3T4WTC3y5rAoAH3xf/exBiBpLKbfPflvlDVV7soBc2BPg==
danny74
Post by danny74 »
The source file '/BDMV/STREAM/00009.m2ts' is broken or invalid at offset 20383537152. An attempt is made to work around this
The source file '/BDMV/STREAM/00009.m2ts' is broken or invalid at offset 20383586304. An attempt is made to work around this
AV sync issue in stream 0 at 0: 35: 08.940: video frame timecode differs by + 41.7ms
To save track 1 in file F: /Video//title01.mkv failed
Encountered 29 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/ ...
0 titles were saved, 1 failed
that happens at every UHD
st4evr
Post by st4evr »
danny74 wrote: Thu Oct 18, 2018 4:23 am The source file '/BDMV/STREAM/00009.m2ts' is broken or invalid at offset 20383537152. An attempt is made to work around this
1. Ok what the EXACT model number of your LG Drive and what is the firmware number it currently has installed? Include the NS code in your reply as shown in the sticker that is on the actual physcial drive.
2. Read these:
viewtopic.php?f=8&t=9288&p=40053&hilit= ... set#p40053
viewtopic.php?f=8&t=17147&p=60898&hilit ... set#p60898
3. As it’s discussed in one of those threads, try another ripping application that supports UHD BD disc ripping to see what happens. Does the disc rip successfully? Or does it also return errors? Etc.
