UHD drives
Locked
st4evr
Re: UHD drives
Post by st4evr » Thu Apr 05, 2018 7:09 pm
XDUDE3D wrote:Just received a ASUS BW-16D1HT but manufactured January 2018 (3.02).....
Anyway I can salvage this? Or is another buy'n'hope it?.... :(
See this thread.
http://www.makemkv.com/forum2/viewtopic ... 16&t=17058
Newbliss
Re: UHD drives
Post by Newbliss » Thu Apr 05, 2018 9:48 pm
I thought the 3.02 FW worked though? I'm having the same issue of January 2018 manufacture date 3.02 FW but no discs or reading. Might just be bad luck with discs having different keys. Anyone know if there is truly no hope for my drive?
XDUDE3D
Re: UHD drives
Post by XDUDE3D » Thu Apr 05, 2018 9:55 pm
Haha, Thanks! I already stumbeled onto that, got my drive reflashed clean to 3.02 and currently have passengers UHD going just fine! Thanks again!
And anyone else with my same issue, the above linked topic IS THE ANSWER. :D
st4evr
Re: UHD drives
Post by st4evr » Thu Apr 05, 2018 11:25 pm
Newbliss wrote:I thought the 3.02 FW worked though? I'm having the same issue of January 2018 manufacture date 3.02 FW but no discs or reading. Might just be bad luck with discs having different keys. Anyone know if there is truly no hope for my drive?
See this thread.
http://www.makemkv.com/forum2/viewtopic ... 12&t=17313
Clarifies a bit on some of the issues discovered/discussed so far with "newer" 3.02 firmware now shipped with those drives.
tapidlittle
Re: UHD drives
Post by tapidlittle » Fri Apr 06, 2018 4:32 am
I have a LG BU40N which seems to be an official reader.
Any idea if it will ever be supported?
DEUHD says it's supported but I tried it and it won't work. :(
Also someone here claim he his able to revert an official reader to a friendly reader, what about that?
thanks.
st4evr
Re: UHD drives
Post by st4evr » Fri Apr 06, 2018 5:11 am
That is entirely up to Mike.
Because DeUHD currently supports some official UHD drives does not mean MakeMKV (or other similar apps for that matter) will also support them. Different apps, different development, different developers, and their aproach may vary even though they are all aiming towards the same goal.
Mike has said that at some point one or more official UHD drives may be supported by MakeMKV as he is working on something. When will that be officially released? Only he knows. All we can do is patiently wait until the release of this version is announced and available for download/purchase.
As for the conversion you speak of. Some have been successful and others not so much. You’ll have to decide whether you feel comfortable to give that method a try or not.
tapidlittle
Re: UHD drives
Post by tapidlittle » Fri Apr 06, 2018 11:57 am
st4evr wrote:That is entirely up to Mike.
Mike has said that at some point one of more official UHD drives may be supported by MakeMKV as he is working on something. When will that be officially realeased? Only he knows. All we can do is patiently wait until the release of this version is announced and available for download/purchase.
As for the conversion you speak of. Some have been successful and others not so much. You’ll have to decide whether you feel comfortable to give it a try or not.
thanks.
mtucker
Re: UHD drives
Post by mtucker » Sat Apr 07, 2018 1:42 pm
You sure can. Use the clean 3.02 FW given just a few posts before yours. My January 2018 drive would not read a UHD disk when I got it, but works great after I dumped my FW, combined with the clean, and reflashed. My computer skills are mediocre, but I got through the FW process following this thread https://www.makemkv.com/forum2/viewtopi ... 16&t=17058
lujan
Re: UHD drives
Post by lujan » Sun Apr 08, 2018 8:58 pm
Will this external drive work with UHD discs and MakeMKV?
ASUS USB 2.0 / USB 3.0 External 16X Blu-Ray Re-writer MacOS Compatible Model BW-16D1X-U LITE/BLK /G /AS
Re: UHD drives
Post by Woodstock » Mon Apr 09, 2018 12:07 am
No, the BW-16D1X-U is not a BDXL-capable drive, despite its model number, and description in the ad you originally linked to.
I bought one, and then gave it away to a Mac user, who then put it on his Windows box because the Mac didn't like it very much.
lujan
Re: UHD drives
Post by lujan » Mon Apr 09, 2018 1:57 am
Woodstock wrote:No, the BW-16D1X-U is not a BDXL-capable drive, despite its model number, and description in the ad you originally linked to.
Are there any external drives that work?
tapidlittle
Re: UHD drives
Post by tapidlittle » Mon Apr 09, 2018 11:43 am
tapidlittle wrote:I have a LG BU40N which seems to be an official reader.
thanks.
I have contacted DeUHD for my drive and they say I need firmware A101, now I have A102.
Anyone know where I can get this firmware?
thanks.
B17NNS
Re: UHD drives
Post by B17NNS » Mon Apr 09, 2018 7:19 pm
Mine has just arrived. Manufactured September 2017. Haven't got an enclosure yet but will this work out of the box?
st4evr
Re: UHD drives
Post by st4evr » Mon Apr 09, 2018 9:33 pm
thanks.
They are advising you downgrade. READ this thread carefully and follow the instructions if you wish to downgrade:
And again as it has been CLEARLY stated before, if you wish to have support for this drive at this time, you will have to buy DeUHD (if you have not already).
alexcoluzzi32
Re: UHD drives
Post by alexcoluzzi32 » Fri Apr 13, 2018 7:22 am
WH16NS40
SVC CODE: NS50
ROM version 1.03
Built January 2018
I'm hosed yes?
Locked
