What is in the MAKEMKV folder and any reason to keep it?
mike23
Post by mike23 »
Just wondering if this folder is OK to delete?
Assuming this is all stripped encryption data?
mike23
Re: What is in the MAKEMKV folder and any reason to keep it?
Post by mike23 »
Assuming no reason to keep the files....
Well, if you were going to have MakeMKV convert the backup to MKV files, you probably would want to keep that information, but... If the Backup is your end-all "product", it should not be needed.
