Percy Jackson
moviebuff
Percy Jackson
Post by moviebuff »
Anyone else having a problem with Percy Jackson BD? I downloaded the latest Svq but nada
dirio49
Re: Percy Jackson
Post by dirio49 »
To help the author
say the region of the bd,country.
post/emai the bd+ dump.
For BD+ failures you need to enable BD+ dump in preferences and send it to support@makemkv.com
thanks
moviebuff
Re: Percy Jackson
Post by moviebuff »
Ya I was trying to see the BD dump in the folder I set but I dont see it.
thudman99
Re: Percy Jackson
Post by thudman99 »
yeah, It doesnt work for me either
Submitted the BD+ Dump File
setarip_old
Re: Percy Jackson
Post by setarip_old »
The SVQ file appears to have now been updated for this title ;>}
thudman99
Re: Percy Jackson
Post by thudman99 »
Doesnt work for me. MakeMKV doesnt seem to be using the SVQ file I downloaded, however. Hmmm - worked for Avatar...
MakeMKV v1.5.6 beta win(x64-release) started
Loaded 8 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
BD+ dump directory is not accessible, BD+ dump not saved
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
setarip_old
Re: Percy Jackson
@thudman99
How long ago did you download the "allcombo.svq" file and place it in your "SVQ" folder?
thudman99
Re: Percy Jackson
Post by thudman99 »
Between 7:25 and 7:45pm, and again just now
Note: Region A/US
dirio49
Re: Percy Jackson
Post by dirio49 »
Then your setting are wrong.
Look at the setting and see what folder have you told makemkv to look for the
SVQ. From the log it looks like you have to set it.
thudman99
Re: Percy Jackson
Post by thudman99 »
dirio49 wrote:Then your setting are wrong.
Thanks for the suggestion, but It is set. I also re-set it to an alternate location and put a freshly downloaded copy of the svq file there, just to make sure.
Additionally, I validation my configuration with an Avatar disk - SVQ works fine for that.
Note Avatar is reported as AACS v16,BD+
while Percy Jackson is reported as AACS v17,BD+
moviebuff
Re: Percy Jackson
Post by moviebuff »
Have the same problem Avatar works fine but not Percy with latest svq
setarip_old
Re: Percy Jackson
@thudman99, @moviebuff
Just as it was with "Avatar", it sounds like differing protection schemes may have been used for releases in different regions ad, possibly different 'packages" (sellthrough, two disc, one disc, rental, etc.).
Did you send in your dumps for analysis?
thudman99
Re: Percy Jackson
Post by thudman99 »
setarip_old wrote:@thudman99, @moviebuff
Sure did...
Re: Percy Jackson
Post by mike admin »
svq is updated for this one.
mlebl1h
Re: Percy Jackson
Post by mlebl1h »
I'm also unable to rip Percy Jackson, and I'm using the latest 1.6.0. Messages start like this:
MakeMKV v1.6.0 win(x86-release) started
Loaded 13 SVQ file(s)
Processing BD+ code using generic SVQ from builtin/00001.svq
BD+ code processed, got 1 FUT(s) for 1 clip(s)
File 00800.mpls was added as title #0
then less that 20% of the way through, I get reads that slow to a crawl and stop. Disk seems to be in great condition. Messages are:
Saving 1 titles into directory E:/Video/Percy_Jackson_and_the_Olympians_The_Lightning_Thief
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4785371136'
Failed to save title 0 to file E:/Video/Percy_Jackson_and_the_Olympians_The_Lightning_Thief/title00.mkv
Seems likely that this is a protection issue, but if it's just a bad disk, I can get another one. Any suggestions appreciated.
BTW, I sent the dump file to support@makemkv.com . On a second attempt, I got the dump file. Tried a different computer too, also no-go.
Saved BD+ dump file as C:/tmp/MakeMKV/dump_Percy_Jackson_and_the_Olympians_The_Lightning_Thief_15348DDD9AAF88F7.tgz
- Tofu
