Film Stars Don't Die In Liverpool (UK Blu Ray)
paulcummin
#1 Post by paulcummin » Wed Mar 28, 2018 10:10 pm
Wow, they've made this one confusing! 402 versions, all with different segments maps! Any ideas which is the correct one please?
guyonphone
Re: Film Stars Don't Die In Liverpool (UK Blu Ray)
#2 Post by guyonphone » Tue Apr 10, 2018 3:12 am
793
JREkiwi
#3 Post by JREkiwi » Tue Apr 10, 2018 5:35 am
I did submit the disk info to mike as described in http://www.makemkv.com/forum2/viewtopic.php?f=8&t=14330
paulcummin
#4 Post by paulcummin » Tue Apr 10, 2018 5:44 pm
guyonphone wrote:793
Awesome, thank you
Steveredrum
#5 Post by Steveredrum » Mon Mar 04, 2019 10:36 am
FIX Is Below
ez009
#6 Post by ez009 » Fri Jun 17, 2022 4:53 pm
793
Thanks 793 - it definitely isn't 00000
Steveredrum
#7 Post by Steveredrum » Tue Jun 28, 2022 11:55 am
Here you go guys this Fix I made will make the Film 100% playable Film Stars Don't Die In Liverpool
Found The Retail PLAYLIST [?.MPLS] In DVDFAB 11
Lots Of Sneaky Shit Going On With The PLAYLISTS So I
Used My Trusty [*.Bat File] - You Must Change All Supplied MPLS
[Film Stars Don't Die In Liverpool (U.K) Retail Version VIA DVDFAB 11]
Just Change All Playlists In The [Liverpool-313.rar] File To PLAYLIST FOLDER &
BACKUP\PLAYLIST FOLDER
All Menus Work 100% AND In Film Popups - Once the Blu-ray is working then you can make an MKV
[Film Stars Don't Die In Liverpool.rar
Flim FIX
(4.74 KiB) Downloaded 489 times
