BatchMKV - batch GUI for MakeMKV
kenneth
Re: BatchMKV - batch GUI for MakeMKV
#121 Post by kenneth » Sat Mar 10, 2018 5:53 am
jknight wrote:Hi. I just installed this, along with MKVToolNix v19 and for every disk (dvd) i have tried I get "Analysis Failed" Am I doing something wrong?
Does it work if you analyse the disks directly with MakeMKV without using BatchMKV?
If yes, is the path for MakeMKV specified correctly in the BatchMKV settings?
BatchMKV - free Windows-based batch processing software for MakeMKV
jknight
#122 Post by jknight » Sun Mar 11, 2018 5:35 pm
Yes, I can rip the discs no problem with mkv, and the path to it in settings is correct as well.
Tyrindor
#123 Post by Tyrindor » Mon Mar 26, 2018 7:52 pm
This program is great, has saved me hundreds of hours.
Couple things:
- I noticed if I add a lot of files (like 50), the program tends to crash.
- Sometimes files fail to analyze, but then clearing them out and retrying works.
- I've came across a few files that fail to convert/process, but both MakeMKV and Mkvtoolnix are able too.
- Sometimes subtitle tracks are not detected. I think it may be related to .ass subs.
user-id
#124 Post by user-id » Tue May 01, 2018 8:15 pm
hi all
the tool is great but I've got some error on settings tabs and press ok:
automatic debug log doesn't work for me
this is my error:
Le informazioni su come richiamare il debug JIT (Just-In-Time) anziché questa finestra
sono riportate in fondo al messaggio.
************** Testo dell'eccezione **************
System.NullReferenceException: Riferimento a un oggetto non impostato su un'istanza di oggetto.
in BatchMKV.fSettings.btnOK_Click(Object sender, EventArgs e)
in System.Windows.Forms.Control.OnClick(EventArgs e)
in System.Windows.Forms.Button.OnClick(EventArgs e)
in System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
in System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
in System.Windows.Forms.Control.WndProc(Message& m)
in System.Windows.Forms.ButtonBase.WndProc(Message& m)
in System.Windows.Forms.Button.WndProc(Message& m)
in System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
in System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Assembly caricati **************
mscorlib
Versione assembly: 4.0.0.0
Versione Win32: 4.7.2633.0 built by: NET471REL1LAST_C
Base di codice: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
System
Versione Win32: 4.7.2556.0 built by: NET471REL1
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
BatchMKV
Versione assembly: 0.7.0.0
Versione Win32: 0.7.0.0
Base di codice: file:///C:/Users/Ghastor/AppData/Local/Apps/2.0/99RK5ZG4.E0J/XDAAC16Z.C32/batc..tion_d74a7c069992ac72_0000.0007_d689f9e11033f903/BatchMKV.exe
NHibernate
Versione assembly: 4.0.0.4000
Versione Win32: 4.0.4.4000
Base di codice: file:///C:/Users/Ghastor/AppData/Local/Apps/2.0/99RK5ZG4.E0J/XDAAC16Z.C32/batc..tion_d74a7c069992ac72_0000.0007_d689f9e11033f903/NHibernate.DLL
System.Data
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Core
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
EventLogger
Versione assembly: 1.0.0.0
Versione Win32: 1.0.0.0
Base di codice: file:///C:/Users/Ghastor/AppData/Local/Apps/2.0/99RK5ZG4.E0J/XDAAC16Z.C32/batc..tion_d74a7c069992ac72_0000.0007_d689f9e11033f903/EventLogger.DLL
FluentNHibernate
Versione assembly: 2.0.3.0
Versione Win32: 2.0.3.0
Base di codice: file:///C:/Users/Ghastor/AppData/Local/Apps/2.0/99RK5ZG4.E0J/XDAAC16Z.C32/batc..tion_d74a7c069992ac72_0000.0007_d689f9e11033f903/FluentNHibernate.DLL
System.Configuration
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Versione Win32: 4.7.2612.0 built by: NET471REL1LAST_B
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
MKVTools
Base di codice: file:///C:/Users/Ghastor/AppData/Local/Apps/2.0/99RK5ZG4.E0J/XDAAC16Z.C32/batc..tion_d74a7c069992ac72_0000.0007_d689f9e11033f903/MKVTools.DLL
System.xml.resources
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.resources/v4.0_4.0.0.0_it_b77a5c561934e089/System.Xml.resources.dll
Microsoft.GeneratedCode
System.Xml.Linq
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
System.Data.SQLite
Versione assembly: 1.0.99.0
Versione Win32: 1.0.99.0
Base di codice: file:///C:/Users/Ghastor/AppData/Local/Apps/2.0/99RK5ZG4.E0J/XDAAC16Z.C32/batc..tion_d74a7c069992ac72_0000.0007_d689f9e11033f903/System.Data.SQLite.DLL
System.Transactions
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
System.Numerics
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
ObjectListView
Versione assembly: 2.8.0.39429
Versione Win32: 2.8.0.0
Base di codice: file:///C:/Users/Ghastor/AppData/Local/Apps/2.0/99RK5ZG4.E0J/XDAAC16Z.C32/batc..tion_d74a7c069992ac72_0000.0007_d689f9e11033f903/ObjectListView.DLL
System.Windows.Forms.resources
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_it_b77a5c561934e089/System.Windows.Forms.resources.dll
Accessibility
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
mscorlib.resources
Base di codice: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_it_b77a5c561934e089/mscorlib.resources.dll
************** Debug JIT **************
Per abilitare il debug JIT, è necessario impostare il valore
jitDebugging nella sezione system.windows.forms del file di configurazione
dell'applicazione o del computer (machine.config).
L'applicazione inoltre deve essere compilata con il debug
abilitato.
Ad esempio:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Quando il debug JIT è abilitato, tutte le eccezioni non gestite
vengono inviate al debugger JIT registrato nel computer,
anziché essere gestite da questa finestra di dialogo.
Please, help me
best regards
sonicboom77
#125 Post by sonicboom77 » Sun Aug 05, 2018 7:49 pm
Hi there!
First off, the software looks very promising, thank you for your hard work to this point!
I've got about ~600 Video_ts folders worth to convert.
Last night, i installed, loaded all the folders, and went to bed. In the AM, it had crashed out, when i try to start it again it won't load. I tried to install it through it's setup program and that won't load either.
Any suggestions?
S.
steve.hoek
#126 Post by steve.hoek » Tue Jan 22, 2019 6:50 pm
Great project!
Any chance the source code for this could be made open-source?
I'd like to contribute to the project; there are several nagging bugs and crashes that I would want to clean up.
Rander
#127 Post by Rander » Sat Apr 27, 2019 6:13 pm
I've got a bit of a problem with this. Sometimes it just refuses to start? I get a little window saying "Checking program demands" (may be something else in english) for a few seconds, and sometimes, the program then start. Mostly, though, nothing more happens! It doesn't start, and there is no trace of it in the task list - almost like it crashes out before it even starts!
Any ideas? Does it do a logfile somewhere that may point me in the right direction?
Rander
#128 Post by Rander » Mon Apr 29, 2019 5:07 am
Rander wrote: Sat Apr 27, 2019 6:13 pm I've got a bit of a problem with this. Sometimes it just refuses to start? I get a little window saying "Checking program demands" (may be something else in english) for a few seconds, and sometimes, the program then start. Mostly, though, nothing more happens! It doesn't start, and there is no trace of it in the task list - almost like it crashes out before it even starts!
Okay, I think I found the solution for this. I had converted a few iso's from a network drive, and when I tried starting the program again, that drive was no longer available, which caused it to crash. Restoring the drive access solved the problem...
zeker
#129 Post by zeker » Sat Jun 08, 2019 1:00 am
I was having great success with only about 1 in 20 ISOs failing to analyze and everything analyzed successfully converting. I haven't changed anything relevant that I can think of. I am now getting a program crash - just disappears - after a successful analysis of a single file added.
I have windows event in two entries from the crash. One from the app, the other from .NET framework. So I installed 4.8 over 4.72 that I had installed but it didn't help.
Here are those two entries:
Source is ".NET Runtime"........
Application: BatchMKV.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.NullReferenceException
at MKVTools.Title.set_Name(System.String)
at BatchMKV.Domain.TitleState.set_Name(System.String)
at BatchMKV.Domain.TitleState.CopySettings(BatchMKV.Domain.TitleState)
at BatchMKV.Domain.SourceState.CopySettings(BatchMKV.Domain.SourceState)
at BatchMKV.fMain.mkvScanCompleted(System.Object, MKVTools.ScanEventArgs)
at MKVTools.Source.OnScanCompletedEvent(System.Object, MKVTools.ScanEventArgs)
at MKVTools.Source.process_Exited(System.Object, System.EventArgs)
at System.Diagnostics.Process.OnExited()
at System.Diagnostics.Process.RaiseOnExited()
at System.Diagnostics.Process.CompletionCallback(System.Object, Boolean)
at System.Threading._ThreadPoolWaitOrTimerCallback.WaitOrTimerCallback_Context(System.Object, Boolean)
at System.Threading._ThreadPoolWaitOrTimerCallback.WaitOrTimerCallback_Context_f(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading._ThreadPoolWaitOrTimerCallback.PerformWaitOrTimerCallback(System.Object, Boolean)
Source is "Application Error" .......
Faulting application name: BatchMKV.exe, version: 0.7.0.0, time stamp: 0x5a8b39b0
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x006c8868
Faulting process id: 0x2fe4
Faulting application start time: 0x01d51d9350c0fce0
Faulting application path: C:\Users\Peter\AppData\Local\Apps\2.0\P9RV1JJ1.APE\XDNJHRXX.QD8\batc..tion_d74a7c069992ac72_0000.0007_d689f9e11033f903\BatchMKV.exe
Faulting module path: unknown
Report Id: 0ce75b24-3a6e-492c-ae03-86743a068ef7
Faulting package full name:
Faulting package-relative application ID:
Any help you can offer will be appreciated!
Edit: Well, a complete uninstall/reinstall seems to have remedied this. So far so good!
Yodathedog
#130 Post by Yodathedog » Mon Aug 19, 2019 6:22 pm
New here but used this software before (along time ago)
I've redownloaded and tried running it but I'm getting an error message
'application did not succeed. Check your network connection, or contact your system admin or network service provider'
Any ideas?
I've had it running once, gave it a folder of. Iso BD rips to analyse and it failed all of them. Something doesn't seem right but not sure what. I've got over 500bd. Iso files I need converted :(
Hope Someone can help
A
indie1138
#131 Post by indie1138 » Thu Sep 05, 2019 8:28 pm
Having a problem, it was working yesterday and now it's not it won't even start before it crashes. I have uninstalled and reinstalled a couple of times with no luck.
I see the notice that it's calling home and then nothing.
Error logs not helping me much maybe someone else can find the issue.
Fault bucket 1255071267940898484, type 5
Event Name: CLR20r3
Response: Not available
Cab Id: 0
Problem signature:
P1: BatchMKV.exe
P2: 0.7.0.0
P3: 5a8b39b0
P4: MKVTools
P5: 1.0.0.0
P6: 5a8b397a
P7: a7
P8: 8d
P9: System.NullReferenceException
P10:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERC392.tmp.dmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERC4AD.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERC4BD.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERC4CD.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERC50C.tmp.txt
These files may be available here:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_BatchMKV.exe_67478a8ceaa1eee2f55a6aa18d45f765325177_4dcfbaae_3a58c7a9
Analysis symbol:
Rechecking for solution: 0
Report Id: d4854001-4036-43c2-82e1-3f82ac15ee06
Report Status: 268435456
Hashed bucket: b62b12814e4c3bbf716ae8ab256a96b4
Cab Guid: 0
Version=1
EventType=CLR20r3
EventTime=132121880854407831
ReportType=2
Consent=1
UploadTime=132121880858470329
ReportStatus=268435456
ReportIdentifier=321b4b71-9c46-4106-b869-3c90320cf805
IntegratorReportIdentifier=d4854001-4036-43c2-82e1-3f82ac15ee06
Wow64Host=34404
Wow64Guest=332
NsAppName=BatchMKV.exe
OriginalFilename=BatchMKV.exe
AppSessionGuid=00000970-0001-0016-032a-a28d2664d501
TargetAppId=W:00065b12e1e8178b5ca3fbbbe7c14165db5800000000!0000b49ba13583f7ccfb24c504ec7aa0775445c02fd2!BatchMKV.exe
TargetAppVer=2018//02//19:20:55:12!388f9!BatchMKV.exe
BootId=4294967295
ServiceSplit=51852728
TargetAsId=3197
IsFatal=1
EtwNonCollectReason=1
Response.BucketId=b62b12814e4c3bbf716ae8ab256a96b4
Response.BucketTable=5
Response.LegacyBucketId=1255071267940898484
Response.type=4
Sig[0].Name=Problem Signature 01
Sig[0].Value=BatchMKV.exe
Sig[1].Name=Problem Signature 02
Sig[1].Value=0.7.0.0
Sig[2].Name=Problem Signature 03
Sig[2].Value=5a8b39b0
Sig[3].Name=Problem Signature 04
Sig[3].Value=MKVTools
Sig[4].Name=Problem Signature 05
Sig[4].Value=1.0.0.0
Sig[5].Name=Problem Signature 06
Sig[5].Value=5a8b397a
Sig[6].Name=Problem Signature 07
Sig[6].Value=a7
Sig[7].Name=Problem Signature 08
Sig[7].Value=8d
Sig[8].Name=Problem Signature 09
Sig[8].Value=System.NullReferenceException
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=10.0.17763.2.0.0.256.48
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=1033
DynamicSig[22].Name=Additional Information 1
DynamicSig[22].Value=2beb
DynamicSig[23].Name=Additional Information 2
DynamicSig[23].Value=2beba6fb4680d73a8c78ca7c24ccdb46
DynamicSig[24].Name=Additional Information 3
DynamicSig[24].Value=94a3
DynamicSig[25].Name=Additional Information 4
DynamicSig[25].Value=94a33baf6c8fba67eda5c683a21bf0a5
UI[2]=C:\Users\Torvald\AppData\Local\Apps\2.0\8LBGB52J.1X2\XCEA34B5.PN0\batc..tion_d74a7c069992ac72_0000.0007_d689f9e11033f903\BatchMKV.exe
LoadedModule[0]=C:\Users\*****\AppData\Local\Apps\2.0\8LBGB52J.1X2\XCEA34B5.PN0\batc..tion_d74a7c069992ac72_0000.0007_d689f9e11033f903\BatchMKV.exe
LoadedModule[1]=C:\WINDOWS\SYSTEM32\ntdll.dll
LoadedModule[2]=C:\WINDOWS\SYSTEM32\MSCOREE.DLL
LoadedModule[3]=C:\WINDOWS\System32\KERNEL32.dll
LoadedModule[4]=C:\WINDOWS\System32\KERNELBASE.dll
LoadedModule[5]=C:\WINDOWS\System32\ADVAPI32.dll
LoadedModule[6]=C:\WINDOWS\System32\msvcrt.dll
LoadedModule[7]=C:\WINDOWS\System32\sechost.dll
LoadedModule[8]=C:\WINDOWS\System32\RPCRT4.dll
LoadedModule[9]=C:\WINDOWS\System32\SspiCli.dll
LoadedModule[10]=C:\WINDOWS\System32\CRYPTBASE.dll
LoadedModule[11]=C:\WINDOWS\System32\bcryptPrimitives.dll
LoadedModule[12]=C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll
LoadedModule[13]=C:\WINDOWS\System32\SHLWAPI.dll
LoadedModule[14]=C:\WINDOWS\System32\combase.dll
LoadedModule[15]=C:\WINDOWS\System32\ucrtbase.dll
LoadedModule[16]=C:\WINDOWS\System32\GDI32.dll
LoadedModule[17]=C:\WINDOWS\System32\gdi32full.dll
LoadedModule[18]=C:\WINDOWS\System32\msvcp_win.dll
LoadedModule[19]=C:\WINDOWS\System32\USER32.dll
LoadedModule[20]=C:\WINDOWS\System32\win32u.dll
LoadedModule[21]=C:\WINDOWS\System32\IMM32.DLL
LoadedModule[22]=C:\WINDOWS\System32\kernel.appcore.dll
LoadedModule[23]=C:\WINDOWS\SYSTEM32\VERSION.dll
LoadedModule[24]=C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll
LoadedModule[25]=C:\WINDOWS\SYSTEM32\MSVCR120_CLR0400.dll
LoadedModule[26]=C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\mscorlib\a5a47e8e5e2880adecca43eb928673f1\mscorlib.ni.dll
LoadedModule[27]=C:\WINDOWS\System32\ole32.dll
LoadedModule[28]=C:\WINDOWS\system32\uxtheme.dll
LoadedModule[29]=C:\WINDOWS\SYSTEM32\dfshim.dll
LoadedModule[30]=C:\WINDOWS\System32\SHELL32.dll
LoadedModule[31]=C:\WINDOWS\System32\cfgmgr32.dll
LoadedModule[32]=C:\WINDOWS\System32\shcore.dll
LoadedModule[33]=C:\WINDOWS\System32\windows.storage.dll
LoadedModule[34]=C:\WINDOWS\System32\profapi.dll
LoadedModule[35]=C:\WINDOWS\System32\powrprof.dll
LoadedModule[36]=C:\WINDOWS\System32\cryptsp.dll
LoadedModule[37]=C:\WINDOWS\SYSTEM32\urlmon.dll
LoadedModule[38]=C:\WINDOWS\SYSTEM32\iertutil.dll
LoadedModule[39]=C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System\2fb412bd4cb1d503da1dc52104e9b1a4\System.ni.dll
LoadedModule[40]=C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll
LoadedModule[41]=C:\WINDOWS\System32\OLEAUT32.dll
LoadedModule[42]=C:\WINDOWS\system32\rsaenh.dll
LoadedModule[43]=C:\WINDOWS\System32\bcrypt.dll
LoadedModule[44]=C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Core\f59803675bd581586c80878df4179d8a\System.Core.ni.dll
LoadedModule[45]=C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Data\7ddfa5bab2f6437acd4ce4fd5e9e4b9d\System.Data.ni.dll
LoadedModule[46]=C:\WINDOWS\Microsoft.Net\assembly\GAC_32\System.Data\v4.0_4.0.0.0__b77a5c561934e089\System.Data.dll
LoadedModule[47]=C:\WINDOWS\System32\WS2_32.dll
LoadedModule[48]=C:\WINDOWS\System32\CRYPT32.dll
LoadedModule[49]=C:\WINDOWS\System32\MSASN1.dll
LoadedModule[50]=C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Drawing\ea876753c0c4a56336a570bda21534c9\System.Drawing.ni.dll
LoadedModule[51]=C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Windows.Forms\a212bd5697ff95c10df6609211086c99\System.Windows.Forms.ni.dll
LoadedModule[52]=C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Configuration\4535ef5b7257234ff4b10886e2a2fd57\System.Configuration.ni.dll
LoadedModule[53]=C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Xml\8154a985b143af64c1c8e7b3c9aef692\System.Xml.ni.dll
LoadedModule[54]=C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Xml.Linq\d871228d22a7097d4f2b4a3c70dc20d4\System.Xml.Linq.ni.dll
LoadedModule[55]=C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Transactions\cdf7d4075ea11385277b8bdda9a19459\System.Transactions.ni.dll
LoadedModule[56]=C:\WINDOWS\Microsoft.Net\assembly\GAC_32\System.Transactions\v4.0_4.0.0.0__b77a5c561934e089\System.Transactions.dll
LoadedModule[57]=C:\Users\*****\AppData\Local\Apps\2.0\8LBGB52J.1X2\XCEA34B5.PN0\batc..tion_d74a7c069992ac72_0000.0007_d689f9e11033f903\x86\SQLite.Interop.dll
LoadedModule[58]=C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Ente96d83b35#\aa2db10fb644846f9cafc60de4d8eff5\System.EnterpriseServices.ni.dll
LoadedModule[59]=C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Ente96d83b35#\aa2db10fb644846f9cafc60de4d8eff5\System.EnterpriseServices.Wrapper.dll
LoadedModule[60]=C:\WINDOWS\Microsoft.Net\assembly\GAC_32\System.EnterpriseServices\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.Wrapper.dll
LoadedModule[61]=C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Numerics\815f616a6a0e191a329301edb2dbba7d\System.Numerics.ni.dll
LoadedModule[62]=C:\WINDOWS\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.17763.678_none_5892d55f78a965e0\comctl32.dll
LoadedModule[63]=C:\WINDOWS\system32\dwmapi.dll
LoadedModule[64]=C:\WINDOWS\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.17763.678_none_7e4f6b0c762c1593\gdiplus.dll
LoadedModule[65]=C:\WINDOWS\SYSTEM32\DWrite.dll
LoadedModule[66]=C:\WINDOWS\System32\MSCTF.dll
LoadedModule[67]=C:\WINDOWS\SYSTEM32\WindowsCodecs.dll
LoadedModule[68]=C:\WINDOWS\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.17763.678_none_4d6478271b999bc5\comctl32.dll
LoadedModule[69]=C:\WINDOWS\System32\clbcatq.dll
LoadedModule[70]=C:\WINDOWS\system32\dataexchange.dll
LoadedModule[71]=C:\WINDOWS\system32\dcomp.dll
LoadedModule[72]=C:\WINDOWS\system32\d3d11.dll
LoadedModule[73]=C:\WINDOWS\system32\dxgi.dll
LoadedModule[74]=C:\WINDOWS\system32\twinapi.appcore.dll
LoadedModule[75]=C:\WINDOWS\system32\RMCLIENT.dll
LoadedModule[76]=C:\Windows\Microsoft.NET\Framework\v4.0.30319\diasymreader.dll
State[0].Key=Transport.DoneStage1
State[0].Value=1
OsInfo[0].Key=vermaj
OsInfo[0].Value=10
OsInfo[1].Key=vermin
OsInfo[1].Value=0
OsInfo[2].Key=verbld
OsInfo[2].Value=17763
OsInfo[3].Key=ubr
OsInfo[3].Value=678
OsInfo[4].Key=versp
OsInfo[4].Value=0
OsInfo[5].Key=arch
OsInfo[5].Value=9
OsInfo[6].Key=lcid
OsInfo[6].Value=1033
OsInfo[7].Key=geoid
OsInfo[7].Value=244
OsInfo[8].Key=sku
OsInfo[8].Value=48
OsInfo[9].Key=domain
OsInfo[9].Value=0
OsInfo[10].Key=prodsuite
OsInfo[10].Value=256
OsInfo[11].Key=ntprodtype
OsInfo[11].Value=1
OsInfo[12].Key=platid
OsInfo[12].Value=10
OsInfo[13].Key=sr
OsInfo[13].Value=0
OsInfo[14].Key=tmsi
OsInfo[14].Value=370123
OsInfo[15].Key=osinsty
OsInfo[15].Value=3
OsInfo[16].Key=iever
OsInfo[16].Value=11.678.17763.0-11.0.140
OsInfo[17].Key=portos
OsInfo[17].Value=0
OsInfo[18].Key=ram
OsInfo[18].Value=32668
OsInfo[19].Key=svolsz
OsInfo[19].Value=190
OsInfo[20].Key=wimbt
OsInfo[20].Value=0
OsInfo[21].Key=blddt
OsInfo[21].Value=180914
OsInfo[22].Key=bldtm
OsInfo[22].Value=1434
OsInfo[23].Key=bldbrch
OsInfo[23].Value=rs5_release
OsInfo[24].Key=bldchk
OsInfo[24].Value=0
OsInfo[25].Key=wpvermaj
OsInfo[25].Value=0
OsInfo[26].Key=wpvermin
OsInfo[26].Value=0
OsInfo[27].Key=wpbuildmaj
OsInfo[27].Value=0
OsInfo[28].Key=wpbuildmin
OsInfo[28].Value=0
OsInfo[29].Key=osver
OsInfo[29].Value=10.0.17763.678.amd64fre.rs5_release.180914-1434
OsInfo[30].Key=buildflightid
OsInfo[30].Value=56DCC875-02E5-4D3F-B28D-5AB4AE897353.1
OsInfo[31].Key=edition
OsInfo[31].Value=Professional
OsInfo[32].Key=ring
OsInfo[33].Key=expid
OsInfo[34].Key=containerid
OsInfo[35].Key=containertype
OsInfo[36].Key=edu
OsInfo[36].Value=0
FriendlyEventName=Stopped working
ConsentKey=CLR20r3
AppName=BatchMKV (beta)
AppPath=C:\Users\********\AppData\Local\Apps\2.0\8LBGB52J.1X2\XCEA34B5.PN0\batc..tion_d74a7c069992ac72_0000.0007_d689f9e11033f903\BatchMKV.exe
NsPartner=windows
NsGroup=windows8
ApplicationIdentity=89729CDF8A6C7E4B43AEFDCFEE0AD016
MetadataHash=-1514668249
Fault offset: 0x0a7d79d0
Faulting process id: 0x970
Faulting application start time: 0x01d564268da22a03
Faulting application path: C:\Users\Torvald\AppData\Local\Apps\2.0\8LBGB52J.1X2\XCEA34B5.PN0\batc..tion_d74a7c069992ac72_0000.0007_d689f9e11033f903\BatchMKV.exe
   at BatchMKV.Domain.TitleState.set_UseStaticValues(Boolean)
   at BatchMKV.Domain.SourceState.InitializeSource(MKVTools.MakeMKV, MKVTools.MKVToolNix, Boolean)
   at BatchMKV.fMain.restoreDataStatePreload()
   at BatchMKV.fMain..ctor()
   at BatchMKV.Program.Main(System.String[])
dangruhn
#132 Post by dangruhn » Tue Mar 10, 2020 11:48 am
The Mission: Impossible Rogue Nation Blu-ray has a colon in {source-file-clean}, which means it cannot be used for a directory name. Could this colon be removed like "." and "_" and replaced with spaces?
rithram
Tracks in output file does not match expected tracks.
#133 Post by rithram » Thu Apr 16, 2020 5:33 am
For most MKV files and ISO files I get the following error:
(Folder BluRay does not seem to trigger this bug)
File: E:\MKVIN\BatchMKV\~Temp\title_t00.mkv
Tracks expected:
Type: Video, Name: , Language: English, Codec: MPEG4, Forced: False, IsEmpty: False
Type: Audio, Name: Surround 5.1, Language: English, Codec: DTS_Multi, Forced: False, IsEmpty: False
Type: Subtitle, Name: , Language: English, Codec: PGS, Forced: False, IsEmpty: True
Type: Subtitle, Name: , Language: English, Codec: PGS, Forced: True, IsEmpty: True
Tracks empty (MakeMKV numbering): 4, 5
Tracks actual:
Type: Video, Name: , Language: Undetermined, Codec: V_MPEG4/ISO/AVC, Forced: False
Type: Audio, Name: Surround 5.1, Language: English, Codec: A_DTS, Forced: False
Type: Subtitle, Name: , Language: English, Codec: S_HDMV/PGS, Forced: False
Tracks actual match expected: False
asset4
#134 Post by asset4 » Fri Jun 12, 2020 12:38 pm
Not sure if I missed a step, but once discs are analyzed how do I make them convert automatically without checking the box each time?
Also, is there a way to make it eject the disc when it's done converting?
bobross
#135 Post by bobross » Sun Nov 15, 2020 3:32 am
The program was sort of working then it failed to convert an ISO and the program just hung. I closed it and rebooted now the program does not launch. I click the BatchMKV icon and the windows 10 blue loading circle shows then nothing.
Uninstalled and then re-install still can't launch the program now.
Some things I noticed are:
I'm using a Windows 10 machine and converting everything "remotely" on my directly connected 10GB fiber NAS connection. When I chose more than 5 ISO files it inevitably fails after analysis or during conversion. It will also just freeze if I try and select more than 20 titles. Not sure if that is due to the remote reads and writes but there is no way I could do a mass conversion with these issues.
I have to paste in the source folder location like //192.168.1.30/movies/iso . Is that type of path causing problems maybe? I have it output on the same type of path on my NAS.
Also on a lot of title that have simple file names it just outputs title.mkv even though I have the option to just use the file name selected.
Man this program is almost so awesome but with these problems I can't really use it.
