Can't Rip 4K After Windows Re-Install. Worked Previously
BradM
#1 Post by BradM » Sat Mar 24, 2018 7:51 pm
Hi, I had to do a reformat and reinstall of Windows 10. Before doing this I was able to rip 4K movies without issue using the hashed keys file. Now even with the same setup every 4K title I try is unable to open. For the life of me I can't figure out what is different now that is keeping this from working correctly. I am using version 1.12.0 with most recent hashed keys from 3-21-18. I would greatly appreciate any feedback as to what might be causing this.
Copy/Paste from MakeMKV
Saved AACS dump file as C:\Users\brad/.MakeMKV/MKB20_v61_Atomic_Blonde_C685.tgz
Saved AACS dump file as C:\Users\brad/.MakeMKV/MKB20_v61_Jack_Reacher_Never_Go_Back_B12B.tgz
Re: Can't Rip 4K After Windows Re-Install. Worked Previously
#2 Post by Woodstock » Sat Mar 24, 2018 8:02 pm
When you did the re-install, did you reconfigure MakeMKV to however you had it customized before? Things like the location of the MakeMKV data directory are important for making UHD work.
BradM
#3 Post by BradM » Sat Mar 24, 2018 8:17 pm
Thanks Woodstock, that was the problem. I had to change the MakeMKV Data Directory in preferences and since doing so is working perfectly again. I really appreciate your help!
TalkSmall
#4 Post by TalkSmall » Mon Apr 09, 2018 5:22 am
Thank you Woodstock,
Had the same problem but it was not due to reinstall, Makemkv just stopped working one day. I really have no clue how the data directory changed but it caused much frustration for me.
Found this thread, changed the data directory, and works again like a charm!
Wanted to bump this post for the good insight.
Cheers.
