Percy Jackson
moviebuff
Percy Jackson
#1 Post by moviebuff » Tue Jun 29, 2010 11:07 pm
Anyone else having a problem with Percy Jackson BD? I downloaded the latest Svq but nada
dirio49
Re: Percy Jackson
#2 Post by dirio49 » Tue Jun 29, 2010 11:23 pm
To help the author
say the region of the bd,country.
post/emai the bd+ dump.
For BD+ failures you need to enable BD+ dump in preferences and send it to support@makemkv.com
thanks
moviebuff
Re: Percy Jackson
#3 Post by moviebuff » Tue Jun 29, 2010 11:30 pm
Ya I was trying to see the BD dump in the folder I set but I dont see it.
thudman99
Re: Percy Jackson
#4 Post by thudman99 » Tue Jun 29, 2010 11:58 pm
yeah, It doesnt work for me either
Submitted the BD+ Dump File
setarip_old
Re: Percy Jackson
#5 Post by setarip_old » Wed Jun 30, 2010 12:25 am
The SVQ file appears to have now been updated for this title ;>}
thudman99
Re: Percy Jackson
#6 Post by thudman99 » Wed Jun 30, 2010 12:45 am
Doesnt work for me. MakeMKV doesnt seem to be using the SVQ file I downloaded, however. Hmmm - worked for Avatar...
MakeMKV v1.5.6 beta win(x64-release) started
Loaded 8 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
BD+ dump directory is not accessible, BD+ dump not saved
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
setarip_old
Re: Percy Jackson
#7 Post by setarip_old » Wed Jun 30, 2010 1:07 am
@thudman99
How long ago did you download the "allcombo.svq" file and place it in your "SVQ" folder?
thudman99
Re: Percy Jackson
#8 Post by thudman99 » Wed Jun 30, 2010 6:04 am
Between 7:25 and 7:45pm, and again just now
Note: Region A/US
dirio49
Re: Percy Jackson
#9 Post by dirio49 » Wed Jun 30, 2010 10:25 am
Then your setting are wrong.
Look at the setting and see what folder have you told makemkv to look for the
SVQ. From the log it looks like you have to set it.
thudman99
Re: Percy Jackson
#10 Post by thudman99 » Wed Jun 30, 2010 11:21 am
dirio49 wrote:Then your setting are wrong.
Thanks for the suggestion, but It is set. I also re-set it to an alternate location and put a freshly downloaded copy of the svq file there, just to make sure.
Additionally, I validation my configuration with an Avatar disk - SVQ works fine for that.
Note Avatar is reported as AACS v16,BD+
while Percy Jackson is reported as AACS v17,BD+
moviebuff
Re: Percy Jackson
#11 Post by moviebuff » Wed Jun 30, 2010 11:37 am
Have the same problem Avatar works fine but not Percy with latest svq
setarip_old
Re: Percy Jackson
#12 Post by setarip_old » Wed Jun 30, 2010 5:12 pm
@thudman99, @moviebuff
Just as it was with "Avatar", it sounds like differing protection schemes may have been used for releases in different regions ad, possibly different 'packages" (sellthrough, two disc, one disc, rental, etc.).
Did you send in your dumps for analysis?
thudman99
Re: Percy Jackson
#13 Post by thudman99 » Wed Jun 30, 2010 10:38 pm
setarip_old wrote:@thudman99, @moviebuff
Sure did...
Re: Percy Jackson
#14 Post by mike admin » Thu Jul 01, 2010 6:38 am
svq is updated for this one.
mlebl1h
Re: Percy Jackson
#15 Post by mlebl1h » Thu Sep 23, 2010 5:40 am
I'm also unable to rip Percy Jackson, and I'm using the latest 1.6.0. Messages start like this:
MakeMKV v1.6.0 win(x86-release) started
Loaded 13 SVQ file(s)
Processing BD+ code using generic SVQ from builtin/00001.svq
BD+ code processed, got 1 FUT(s) for 1 clip(s)
File 00800.mpls was added as title #0
then less that 20% of the way through, I get reads that slow to a crawl and stop. Disk seems to be in great condition. Messages are:
Saving 1 titles into directory E:/Video/Percy_Jackson_and_the_Olympians_The_Lightning_Thief
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4785371136'
Failed to save title 0 to file E:/Video/Percy_Jackson_and_the_Olympians_The_Lightning_Thief/title00.mkv
Seems likely that this is a protection issue, but if it's just a bad disk, I can get another one. Any suggestions appreciated.
BTW, I sent the dump file to support@makemkv.com . On a second attempt, I got the dump file. Tried a different computer too, also no-go.
Saved BD+ dump file as C:/tmp/MakeMKV/dump_Percy_Jackson_and_the_Olympians_The_Lightning_Thief_15348DDD9AAF88F7.tgz
- Tofu
